GH3tt0 fab ITB'S check it out
Here are some shaweet ITB's that my roomate had made..or more so welded together...to bad they funked up on 3 of the intake runners..atleast one turned our decent... throttles were used from a Toyota AE111, intake manifold taken from a 99 si...over all they would have turned out ok.if the machinest wasnt an idiot about welding the runners...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90accord1 »</TD></TR><TR><TD CLASS="quote">over all they would have turned out ok.if the machinest wasnt an idiot about welding the runners...
learn to read 5thgear, and maybe you should take some classes at the local high school on how about to tighten lug nuts..?
B20 vtec, 12:1 JE pistons, Eagle H beam rods, b16 head, z10crank girdle, y21 tranny, toda c's , dsm 440's on hondata stage 2. just the b20 with stock b16 head and ctr cams, built bottom end pumped out 186 at the wheels....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90accord1 »</TD></TR><TR><TD CLASS="quote">B20 vtec, 12:1 JE pistons, Eagle H beam rods, b16 head, z10crank girdle, y21 tranny, toda c's , dsm 440's on hondata stage 2. just the b20 with stock b16 head and ctr cams, built bottom end pumped out 186 at the wheels....</TD></TR></TABLE>
ouch, those numbers arent great, i put down 192 on a stock block, ctr cams
thats going to be a crazy setup, whos building it, yourself, wats it going in?
dr_latino999
Mar 10, 2007 05:26 PM
JDMisGOOD
Feb 23, 2006 03:33 PM
