engine bay dirty
Old May 5, 2003 | 11:51 AM
beaterman's Avatar
Default engine bay dirty
my engine bay is so dirty. what do you guys do to keep your engine bay clean. i live at the beach and it seem impossible to keep sand out of the engine bay. please some help.
Old May 5, 2003 | 11:52 AM
illi Adik's Avatar
Default Re: engine bay dirty (beaterman)
I just clean mine about once a month, fortunately I dont have to deal with the sand like your case.
Old May 5, 2003 | 11:59 AM
emr88's Avatar
Default Re: engine bay dirty (Jackson4Door)
Follow the steps outlined at this webpage for a nice, detailed engine bay:
http://www.apexcone.com/TechPr....html
Substitute Meguiars Vinyl and Rubber cleaner instead of AmorAll
Old May 5, 2003 | 12:03 PM
bryan305's Avatar
if it's just sand, you should be able to just rinse it off quickly when you wash your car. It's the salt that you need to be concerned with. That'll oxidize you engine and all the metal parts that aren't coated.
Old May 5, 2003 | 12:31 PM
iH8RICERZ's Avatar
Default Re: engine bay dirty (bryan305)
simple green
Old May 5, 2003 | 12:39 PM
Seedc2's Avatar
Default Re: engine bay dirty (iH8RICERZ)
ive seen the works of simple green (patrick) but ive heard from a detailer that you should use a product containing an ingredient called "orange ??" If someone knows please list the name.
Old May 5, 2003 | 01:50 PM
Whitegsr2000's Avatar
Default Re: engine bay dirty (kendogg)
I just use Power Clean. That stuff can clean anything
Old May 5, 2003 | 01:57 PM
TEXN3's Avatar
Default Re: engine bay dirty (Whitegsr2000)
castrol makes a great cleaner. blue spray bottle. after you get it all clean. once a week just use a lint clothe and wipe off the sand. or rinsing with light-pressure water will work. i get mine steam-cleaned once a month at the honda dealer for free.
Old May 5, 2003 | 02:01 PM
beaterman's Avatar
Default Re: engine bay dirty (texnteg)
do you work at honda. i really need to get this sand out and i dont want to put water anywhere near my engine.
Old May 5, 2003 | 02:21 PM
Rick's Avatar
He doesn't mention covering anything in the engine bay up. Shouldn't you cover up the obvious parts? Alternator, distributor, battery?
Old May 5, 2003 | 02:46 PM
migs's Avatar
Default Re: engine bay dirty (Rick)
I just spray a mist of water into the engine bay. I use a small towel to cover up the distributor and its nearby components. After that, I just douse the entire engine bay with Simple Green.
Simple Green has no acidic chemicals in it. So it will not tarnish any of the metal finishings. Let it stand there for a 5-7 minutes, then rinse it again with water. Repeat this step once more.
After that. Get a towel, and just absorb all the major water puddles. After that is done. Spray a lot of that NO TOUCH TIRE FOAM. Spray everything, I mean, everything!!!
Let it dissinigrate (sp?) and just clean the liquids off with a towel. your car will look just about brand new.
Old May 6, 2003 | 08:50 AM
emr88's Avatar
Default Re: engine bay dirty (Migs)
I also use Simple Green and as little water as possible. Only thing I cover up is the distributor. I just put a grocery bag over it and wrap it up tightly so no water gets in there.
I use the Meguiars Vinly and Rubber cleaner since it gives everything a nice finish, not too slimey and shiney.
Old May 6, 2003 | 08:57 AM
AK94GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migs &raquo;</TD></TR><TR><TD CLASS="quote">I just spray a mist of water into the engine bay. I use a small towel to cover up the distributor and its nearby components. After that, I just douse the entire engine bay with Simple Green.
Let it dissinigrate (sp?) and just clean the liquids off with a towel. your car will look just about brand new. </TD></TR></TABLE>
I dont know about anyone else, but Migs has the best way to do it, tire foam works great, actually i need to do this, since mine looking kind of dirty since winter just got over not to long ago
Old May 6, 2003 | 09:19 AM
nek0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick &raquo;</TD></TR><TR><TD CLASS="quote">He doesn't mention covering anything in the engine bay up. Shouldn't you cover up the obvious parts? Alternator, distributor, battery?</TD></TR></TABLE>
Yep I cover the distributor cap and any electrical assembly, fuse box, etc and go easy around the area. Spray some simple green, leave it on, spray it off with high pressure washer. Just be careful with the high pressure sprays cause I did chip out some paint from the engine cover
G-Robinson
Apr 20, 2009 07:10 PM
trepteg
Mar 31, 2008 08:02 AM
EGTeK
Mar 13, 2003 07:43 AM
