Going JDM front-end...will HID work?
Old Jul 4, 2001 | 10:05 PM
SpeedMonkeyRacing's Avatar
Default Going JDM front-end...will HID work?
I'm going to get the JDM front-end..but I was wondering if my phillip HID light will work on it or not? I thought the light is universal?
Jeff-
Old Jul 4, 2001 | 10:07 PM
bigTom's Avatar
Default Re: Going JDM front-end...will HID work? (ProjectD2-Jeff)
yes... u can get hid's to work on the non-hid jdm headlights... the actual jdm lights have a ballast ith them and i believe thay are a little differant... the non-hid is like a normal headlight... if your hid's wont fit... it shouldnt be hard to make them work...
Old Jul 6, 2001 | 08:51 PM
StanBo's Avatar
Default Re: Going JDM front-end...will HID work? (4dr-gsr)
You can definitely make your hids work in the new setup. The one problem I can see you running into is the bulb housing itself. If the bulb code is different than the one you are running now the bulb will not be a simple plug and play. It might take some bracket making. I get HID bulbs that are made to fit the old halogen housings. They are the best. There are fewer worries. The only thing that is left is to find a place to mount your ballasts.
MiKeEH
Jul 12, 2009 09:35 AM
crx_si-r
Jun 15, 2009 10:14 AM
Type Wah
Jul 8, 2007 05:23 PM
kuja
Jul 5, 2004 08:38 PM
DuNkiN
Aug 27, 2002 07:44 PM
