Tranny Issues
Old May 5, 2003 | 06:58 AM
preluder's Avatar
Default serious **** yo
yo i got a accord with a prelude motor and its making noises cause of the clutch i believe now. And uhhh for now its having some real problems now its making noises being that i couldnt fix the probelem i had from goin from first to get into 1st gear and reverse . Its the throw-out bearing can it actually do that. and it also might be the low fluid level? any suggestions?
Old May 5, 2003 | 07:24 AM
YeuEmMaiMai's Avatar
Default Re: serious **** yo (preluder)
either you got a messed trans or you did not install something properly. double check all the work you did and fluid levels
Old May 5, 2003 | 07:32 AM
preluder's Avatar
Default Re: serious **** yo (YeuEmMaiMai)
yo bro im gonna do that rght now Thanks
Old May 5, 2003 | 08:06 AM
accordm3's Avatar
did you grease the throw out bearing when you put it in? if not it will squeek like a ******
Team ICU
Aug 11, 2008 01:31 PM
mikestypeRR
Dec 1, 2005 05:25 PM
DMF
Jun 22, 2003 07:42 PM
machine4321
Jun 1, 2003 10:41 PM
Spade
Nov 14, 2001 06:00 AM
