Axxis Ultimates
Old May 5, 2003 | 12:22 AM
phatnadz's Avatar
Default Axxis Ultimates
My OEM pads are getting worn down, so I'm contemplating buying these Ultimates because they're just as cheap as the stock pads.
Seeing that my current brake system is completely stock, will I notice any benefit from these pads over OEM? How long will these pads last when compared to the OEM? Will they warp my rotors quicker than the OEM pads?
Thanks!
Old May 5, 2003 | 02:01 AM
Cseika02's Avatar
I don't know about the axxis ultimates with OEM rotors.. but I have the Axxis Ultimates with Brembo blanks.. and you def can tell the difference between stopping power... but it should be better than OEM pads
Old May 5, 2003 | 05:20 AM
Gennady's Avatar
New User
You should definetly get Axxis Ultimates. I would recommend this pad for anyone for street use. You will notice harder initial bite and less resistence to fade. They will not warp your rotors but will be a little bit harsher on them than OEM Nissin pads due to the big difference in friction coefficient as per the chase test. They will also last a little bit less for that same reason, but the price/benifit is definetly worth getting Ultimates. You should try http://www.cobaltfriction.com to buy these. HT members get a 10% discount, and customer service is unparelleled.
TypRice
Honda Motorcycles
May 19, 2009 04:59 PM
97civicsedan
16
Aug 5, 2005 10:01 PM
azian21485
Jun 9, 2005 01:58 PM
onemanlan
Oct 31, 2004 02:38 PM
full Circling
Jul 10, 2004 01:30 PM
