Z10 Radius Arm Traction System for DC2/ 1992 - 2000 Civic - Del Sol
Old May 4, 2003 | 09:36 PM
TRuST's Avatar
Default Z10 Radius Arm Traction System for DC2/ 1992 - 2000 Civic - Del Sol
Used but in good condition Z10 Radius Arm Traction System for 1994-2000 Integra/1992 - 2000 Civic - Del Sol for $225 shipped anywhere inside the US anywhere else please contact me so that we may arrange something.
for a bigger picture goto => http://www.lions.odu.edu/~wmarceli/i...10overview.jpg
Here's some info on the Z10 radius arms from their website.
Completely Eliminate Wheel-hop!
Bolt-On Traction Uses Factory Bolt Holes
Launch Harder, Lower 60’ times
Retains Complete Suspension Travel—No Binding
CNC Machined Components, TIG Welded Crossmember
Retains Factory Ground Clearance
Allows for Caster Adjustment
Suitable for both Road Race and Drag Race Applications
The Z10 Radius Arm Traction System can offer your car increased durability, improved traction, lower 60' times and will completely eliminate wheel-hop. It's specially engineered design provides extra stability, enabling you to not only launch harder but to retain complete suspension travel, no binding! Suitable for both road and drag racing, Z10's Radius Arm Traction System retains factory ground clearance and allows for caster adjustment. Mounting brackets are CNC pocketed for lightweight starts. Radius rods are high strength aluminum alloy. Using factory bolt holes, this true bolt-on unit will definitely improve your car's performance! Although this model comes standard with premium steel-rod ends, aluminum rod-ends are available upon request. A customizable powder-coating or a clear-coated exposed welds steel finish is also available. Ask us about our ultra-lightweight chrome-alloy option too!
Here's Z10's website if your are interested.
http://www.z10eng.com
07jdmfit
Jul 30, 2009 04:53 PM
flyweed
May 22, 2007 10:54 AM
skip122
Feb 15, 2007 12:07 PM
