serious problems.
eversince my h22a swap I have been have been having problems with my car. I have already ordered the release bearing for my clutch. I am gonna have them bleed the slave cylinder now here are mmore problems. The car bogs off and on off and on. I saw some pressure hoses loose I connected them the car does the same ****. So i hear the pipes clanking so the bolts on them are probably loose. I notice that the oxygen sensor is cut and not even hooked up. And the car idles funny it smells like its burning rich I didnt even check the sparkplugs and. The car idles and shifts hard . could it be the relase bearing? and sometimes when im driving or when i let the car roll off it seems to bog and bog like it wants to shut off like in a lower gear I plan to get these things fixed but damn i should know better than to mess with this persons shop .
Can anyone tell me what other **** i need to look out for please.
check the psi of fuel pressure, the o2 sensor is off=bogging
is your h22 misfiring also?
take out the spark plug to check.
what have you dont to it? stock motor right?
is the map sensor sitting funny?
jason418436
Oct 28, 2004 09:55 PM
dogfood
Oct 6, 2004 04:45 PM
