timing belt issues?
Old May 4, 2003 | 05:02 PM
420aNT's Avatar
Default timing belt issues?
My timing belt is riding off the cams by about 1/4 of an inch. What did I do wrong? I have retensioned the belt over and over but it always moves out about 1/4" and rubs on my timing belt cover? My car is a 2001 GSR with a built bottom end and the head is done with all Ferrea valve train. I tried both the stock cam gears and aftermarket with no change in the position. Someone please help.
Old May 4, 2003 | 05:19 PM
420aNT's Avatar
Default Re: timing belt issues? (18gTeg)
ttt
Old May 4, 2003 | 05:54 PM
Tweakmeister's Avatar
off a tooth?
Old May 4, 2003 | 06:39 PM
420aNT's Avatar
Default Re: timing belt issues? (Tweakmeister)
how would that make it slide off the cams 1/4"? The timing is dead on as I have redone it over and over to try and fix the problem
Old May 4, 2003 | 07:32 PM
bearingburner's Avatar
okay. what do you mean by 1/4". if you are referring to slack then you may need pulley up on the tensioner a bit instead of relying on the weak spring to tension it. aftermarket cam sprockets help in adjusting slack a bit. i never had trouble installing the t-belt. you may want to double check you got the right belt. well good luck
Old May 5, 2003 | 05:59 AM
420aNT's Avatar
Default Re: timing belt issues? (bearingburner)
no the belt is tight. Instead of riding totally on the cams, the belt is 1/4" off the outside of the cams.
Old May 5, 2003 | 06:38 AM
speedymon's Avatar
Umm. Push it back in. Did you forget to put the ring like thingy back on the crank gear?
Old May 5, 2003 | 08:08 AM
1bad-eg's Avatar
Default Re: timing belt issues? (speedymon)
Yeah, check that big washer behind the crank pulley. It's designed to keep the t-belt from sliding out, just like you're describing.
dleccord
Apr 13, 2020 08:03 AM
LS_VTECteggy
Jun 11, 2010 01:34 PM
BuiltCivic99
17
Aug 27, 2009 09:15 PM
2000fbp
Aug 9, 2003 09:18 PM
superR303
Apr 28, 2002 05:57 AM
