whats the voltage of the yel/blk wires at ecu called -power input- 12v right?
Old May 4, 2003 | 04:01 PM
Neukin's Avatar
Default whats the voltage of the yel/blk wires at ecu called -power input- 12v right?
tell me please!!!!!!!
Old May 4, 2003 | 04:32 PM
Neukin's Avatar
Default Re: whats the voltage of the yel/blk wires at ecu called -power input- 12v right? (toyosupr)
no one knows... dont any of you do your own work... i just need to make sure the ecu is putting out the right amount.
Old May 5, 2003 | 07:54 AM
Neukin's Avatar
bump
Old May 6, 2003 | 04:26 AM
Neukin's Avatar
bump part 2
Old May 6, 2003 | 07:44 AM
untitled's Avatar
told you they wouldnt reply. just test it on my car.
Old May 6, 2003 | 07:49 AM
raene's Avatar
What are you asking? What car? What year? What ECU? Which pinouts?
Old May 6, 2003 | 07:51 AM
untitled's Avatar
Default Re: whats the voltage of the yel/blk wires at ecu called -power input- 12v right? (raene)
AEM EMS, obd-1, b16 in crx. what is the voltage supposed to be when you test it with a multimeter.
Old May 6, 2003 | 08:10 AM
raene's Avatar
Default Re: whats the voltage of the yel/blk wires at ecu called -power input- 12v right? (88crx91integra)
Power input to the ECU should be equal to battery output voltage without the car running... so 12.5 volts or thereabouts...? That can't really be your question... can it?
Old May 6, 2003 | 09:24 AM
Neukin's Avatar
ya i think you have to have the key turned to on or start to ge the reading... mine is 6.7v i thought it was 12v just wanted to make sure. but since im reading 6 something i dont know whats wrong. its the yel/blk wires known as powerinput on a 91 and IGN1 on a 92 i have a few differnet wiring diagrams so i dont know what to call it really
Old May 6, 2003 | 09:32 AM
raene's Avatar
I might be wrong on the 12V thing... I'm @ work so I can't check too many OT sites (firewalled + monitored) but I'd take a look at things like HASport's wiring diagrams if you say it's for a '91 model year.
lilmartian09
Oct 27, 2010 04:09 AM
prelude_93vtec
Aug 18, 2008 11:50 PM
djbrandonr
Feb 5, 2007 05:08 PM
crx88fast
Dec 30, 2005 05:19 PM
MrMayhem
Nov 22, 2005 07:54 PM
