B16a axles are not spinning?????HELP
Old May 4, 2003 | 03:46 PM
TheHatchHog's Avatar
Default B16a axles are not spinning?????HELP
Just tried to get my car going today. After I took it off the jacks, I tried to roll it out of my garage before I started it. The front wheels feel like they are locked. I Have a b16a in a 89 CRX DX. I installed the correct Hasport Axles. They fit in with ease when I intstalled them, what could be the problem????HELP
Old May 4, 2003 | 06:24 PM
CRexcellence's Avatar
New User
Default Re: B16a axles are not spinning?????HELP (civicciviccivic)
Did you pull the knuckle rings out of the hub? when i put my motor in I didnt see them because they were smashed into the hub and my axles wouldnt move either so check that out
Old May 4, 2003 | 06:27 PM
Hondasaurs's Avatar
Also make sure both axles are pushed all the way into the tranny. If they are not the car wont move. You can actually shift throught the gears when the axles are not in all the way.
Old May 4, 2003 | 07:54 PM
Rywire's Avatar
Default Re: B16a axles are not spinning?????HELP (ZC_CRX)
take off the dust shields on the axles. Ryan
blake22
Feb 18, 2007 06:59 AM
LD_EGSICK
Sep 20, 2003 08:11 PM
wutupnut
18
Mar 16, 2003 07:33 PM
