98 gsr showing code!help if u can.
my 98 gsr is showing code P0113,meening intake air temperature circuit high input.....I have already tried swaping my friends intake air temp sen.out with mine and tried clearing the codes but no luck
what would be causing this to happen but,most inportantly how would i go about solving this?
You've already swapped the sensor, so now you gotta check the wiring from there back to the ECM. That can be a pain, get a DMM & look for shorts or opens.
The IAT sensor works by changing resistance in a circuit. A high input code would indicate that either the sensor is unplugged or there's a break in the wire causing an infinite amount of resistance.
