dx w/gsr wont go pass 4K?
Old Jul 4, 2001 | 12:02 PM
dr650's Avatar
New User
Default dx w/gsr wont go pass 4K?
any1 has diz problem b4.i have 91 dx w/gsr.da problem is dat it wont pass 4k rpm.any1 pls? distributors n coil r ok.
Old Jul 4, 2001 | 02:36 PM
court's Avatar
25 Year Member
Default Re: dx w/gsr wont go pass 4K? (dr650)
clynder sensor?
Old Jul 4, 2001 | 10:09 PM
slowerthanu's Avatar
New User
Default Re: dx w/gsr wont go pass 4K? (court)
Remove the ***** valve from the exhaust reciprocator and place a green wire across the valve cover j/k
Old Jul 5, 2001 | 01:23 PM
andrew n's Avatar
Default Re: dx w/gsr wont go pass 4K? (slowerthanu)
Is that in English?
Old Jul 5, 2001 | 08:06 PM
accordsir_h22a's Avatar
New User
Default Re: dx w/gsr wont go pass 4K? (andrew n)
You forget to wire up the VTEC??
Old Jul 6, 2001 | 05:00 AM
civicgsr's Avatar
Default Re: dx w/gsr wont go pass 4K? (accordsir_h22a)
Sounds like you "really" need to check your wiring. You have to have an engine code. Other than a massive fuel system issue, or injector issue, I can't think of another reason why you would have that problem.
A 4k limit would not be caused by the lack of VTEC wiring. You can still run it to redline...just no power.
Oh yeah, please speak english...
Old Jul 6, 2001 | 05:41 AM
92Si's Avatar
New User
"any1 has diz problem b4.i have 91 dx w/gsr.da problem is dat it wont pass 4k rpm.any1 pls? distributors n coil r ok"
Translate:
"Has anyone encountered this problem before?" I have a 91 (civic)dx with a GSR motor. The problem is that it will not (rev) past 4 thousand RPM. Can anyone please help? The distributor and the coil are okay."
Now that I have translated it for your ghetto *** you may receive more help, because people will know what the **** you are saying.
Old Jul 6, 2001 | 11:41 AM
martilafox's Avatar
New User
Default Re: dx w/gsr wont go pass 4K? (92Si)
bravo 92si . . . . .bravo.
Old Jul 6, 2001 | 05:12 PM
B18CJDM's Avatar
Oh now I understand what the hell he was saying sorry can't help either though Here have another.
Old Jul 9, 2001 | 08:43 AM
ATYPR's Avatar
Default Re: dx w/gsr wont go pass 4K? (B18CJDM)
sounds like the oil pressure sensor for vtec is not wired up
[Modified by FUCATYPR, 5:43 PM 7/9/2001]
Old Jul 9, 2001 | 10:37 PM
GZR4DR's Avatar
Default Re: dx w/gsr wont go pass 4K? (FUCATYPR)
I like your translation. I am guessing 50% chance you have a messed up ecu. Have a nice day.
almostvtec
May 29, 2011 03:52 AM
HatchSpeeD
Nov 2, 2003 06:51 PM
4ghatch
Apr 26, 2003 07:13 AM
dr650
Jul 5, 2001 05:45 AM
dr650
Jul 4, 2001 12:19 PM
