SI & HF Injectors?
Old May 4, 2003 | 12:11 AM
Canonm7's Avatar
Default SI & HF Injectors?
Hey,
Are the SI and HF Injectors the same size? I have an HF manifold and want to use it for my MPFI swap on my 91 DX. Is this possible or would I be better off using the SI parts?
Thanks in advance.
Old May 4, 2003 | 02:04 AM
Noahk's Avatar
Default Re: SI & HF Injectors? (Canonm7)
They are the same.
Old May 4, 2003 | 08:10 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: SI & HF Injectors? (Noahk)
thats what i thought....
i am curious why they have different part numbers on http://www.hondaautomotiveparts.com. they look visually the same, theres no way that i know of to tell them apart. so i still assume they are the same...just always different part numbers for some reason.
Old May 4, 2003 | 08:51 AM
NCchris's Avatar
My research says the injectors are the same, but you might want to re-think your decision on the HF manifold. The runners are tiny and the throttlebody is small. It was designed for economy. IE keeping the intake velocity up with small volume. I don't know your goals, but if it is performance, as in more hp, I'd stick with the Si.
HTH
chris
Old May 4, 2003 | 09:06 AM
civicdragger818's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canonm7 &raquo;</TD></TR><TR><TD CLASS="quote">Hey,
Thanks in advance.</TD></TR></TABLE>
I know that the intake mani off of the si has fatter runners. If it were me I would use the si parts.......
Old May 4, 2003 | 09:15 AM
Rob!'s Avatar
Default Re: SI & HF Injectors? (civicdragger818)
yeah when i had the hf motor in there the intake manifold was very small it didnt look very high flowing at all....i would deff. stick with the SI parts...
Old May 4, 2003 | 10:01 AM
Canonm7's Avatar
Thanks everyone.
shadycrx
11
Jan 2, 2006 07:03 PM
SOHCrx
Nov 27, 2003 07:39 AM
91crxmachine_2
24
Oct 11, 2003 03:48 PM
Crxfanatic15
10
Jan 16, 2003 10:49 PM
hybridcrx
11
May 27, 2002 05:06 PM
