Crank Agle sensor code
Did a b16 swap in my car today, finished up and got code 6, CAS. I know the cas is in the dizzy but it throws it regardless of another distributor or not (swapped with a friend). Anyone have any ideas what could be wrong?
91 CRX Si
PWO ECU
B16a1
90 LS Dizzy
please please help.
Thanks peeps.
91 CRX Si
PWO ECU
B16a1
90 LS Dizzy
please please help.
Thanks peeps.
make sure that you dont have the blue/yellow and the blue/green wires switched (you might even want to switch them to make sure), or the problem i had was the connection i made inside the car of one of those wires (the directions say to "splice" the wire into the location but you just cut and extend into the engine bay) the wire i am talking about was one of the two thin wires in a orange covering. goodluck fixing it
What wires are you talking about? I didn't re-do any of the wires to the CAS/Dist. Just vtec & oil pressure (euro PWO has no knock or second O2). I'm confused.
Well I Hacked a leg of my D16 dist and threw that on. Now the car will go a few miles and hit vtec and everything until the code turns on. With the other distributors the light came on before I even started the car.
I checked wires from the ecu to the dist and they are working fine, I have no idea what else to do.
Blaze45
Dec 13, 2003 06:28 PM
JonGP4
Jul 26, 2003 06:13 AM
