Stock fuel pressure on type-r? with hose on/off
Old Jul 4, 2001 | 07:53 AM
89civicdx's Avatar
Default Stock fuel pressure on type-r? with hose on/off
Can someone tell me the stock fuel pressure on a type-r with the hose on/off
Old Jul 4, 2001 | 09:43 AM
ARunto's Avatar
Default Re: Stock fuel pressure on type-r? with hose on/off (89civicdx)
40-42psi with the hose off
-Alan
Old Jul 4, 2001 | 11:17 AM
B18CXr's Avatar
stock pressure is 51-54 psi off vacum.
Old Jul 4, 2001 | 11:22 AM
MackSpeed-616's Avatar
Default Re: Stock fuel pressure on type-r? with hose on/off (B18CXr)
both of you are right.... stock pressure;s can vary greatly and do fit in the ranges above
Old Jul 4, 2001 | 11:34 AM
ZygSpeed's Avatar
Default Re: Stock fuel pressure on type-r? with hose on/off (TurboR616)
sorry, they're not both right.... do you see why.
I asked this question recently and have been playing with my fuel pressure since then.
Arunto -- sort of mis-spoke , because he should have said "with the hose ON".
Jack gave pretty what what the manual says, measured when the hose is OFF.
Yes, it does seem to make about a 10 psi difference when reading the gauge between hose on,
and hose off (hose on giving the lower of the two readings).
speaking of which, I'm off to get a slightly bigger hose clamp for my AEM FPR because It was too tight and started to leak!!
[Modified by zygspeed, 3:36 PM 7/4/2001]
Old Jul 4, 2001 | 11:49 AM
89civicdx's Avatar
Default Re: Stock fuel pressure on type-r? with hose on/off (zygspeed)
OK lets get this straight
40-42psi with the hose on
51-54 psi with the hose off
IS this right ?
Someone confirm this please
[Modified by 89civicdx, 12:50 PM 7/4/2001]
Old Jul 4, 2001 | 12:30 PM
ZygSpeed's Avatar
I'd stick with 40-41 hose on, 50-51 hose off.
Sorry about the confusion.
Notorious_T
Nov 2, 2008 03:02 PM
smallttocs
Oct 24, 2008 12:54 PM
LSVtecEK1
Aug 13, 2004 05:23 AM
[HrZn]4life
Apr 2, 2003 12:37 PM
comptechgsr2000
Feb 13, 2003 04:17 PM
