ls/vtec in 89 civic?
Old May 3, 2003 | 06:24 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default ls/vtec in 89 civic?
i have a friend with a 89 civic hatch that already had an ls engine in it.it was running fine with a 91 ls ecu and distributor.he installed a vtec head and distributor from a 99 si and it will crank and run for a second and then shut off.he changed to a jdm crx b-series distributor and it still does the same thing.we tried two pr4 ecus and a pr6 as well and it still does the same thing.does he have to have a pr3 or should it run with a pr4?also,he is wanting to trigger the vtec with a apexi v-afc.will it work if you just hook up the output from the v-afc to the selenoid or does it have to have the signal from a pr3 ecu.also,if the v-afc will work like that,do you have to hook up the vtec pressure sensor?if so does one go to signal for the ecu and the other to ground or 12v+?also,i know you need to add a second o2 sensor to the pr3 ecu,but what about a knock sensor?if you need a knock sensor,will it go in a ls block?i know this is alot of questions but it sure would help,thanks!
Old May 4, 2003 | 05:57 AM
25 Year Member
Default Re: ls/vtec in 89 civic? (turbotypeR)
anyone?
Old May 4, 2003 | 03:19 PM
25 Year Member
i can't believe knobody knows! do you know anybody else that might know?
ED9
Sep 21, 2009 05:11 PM
civic_si_101
Oct 21, 2008 12:44 AM
tial-eg
Jul 3, 2006 12:20 PM
HondaFanatic708
Jul 12, 2005 11:07 AM
b20turbojason
Jan 14, 2004 03:34 PM
