GSR throttle body install on ITR manifold
Old May 3, 2003 | 05:09 PM
MisterB's Avatar
Default GSR throttle body install on ITR manifold
i am trying to install a GSR TB on my B16 with ITR IM... i searched and i still need help as to how to make it work, do i flip the pulley or us the b16 one, also nipple an the FITV broke off so do i need to replace it or can i just bypass the FITV and take it off
Modified by MisterB at 7:15 PM 5/8/2003
Old May 3, 2003 | 07:52 PM
MisterB's Avatar
Default Re: GSR throttle body install on ITR manifold (cl4show)
anyone?
Old May 4, 2003 | 12:53 PM
MisterB's Avatar
bump
Old May 8, 2003 | 10:15 AM
MisterB's Avatar
Default Re: GSR throttle body install on ITR manifold (MisterB)
still looking for some help
Old May 8, 2003 | 10:56 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MisterB &raquo;</TD></TR><TR><TD CLASS="quote">i am trying to install a GSR TB on my B16 with ITR IM... i searched and i still need help as to how to make it work, do i flip the pulley or us the b16 one, also nipple an the FITV broke off so do i need to replace it or can i just bypass the FITV and take it off
Modified by MisterB at 7:15 PM 5/8/2003</TD></TR></TABLE>
you'll need to swap the throttle pully from the B16 TB over to the GSR TB or just use the B16 TB as a whole. a GSR and 92+B16 TB are the same size anyways. If have a 89-91 B16 TB, then use the GSR tb, as the 89-91 B16 tb is smaller in diameter.
For the FIV, you can just bypass it, and reroute the coolant lines that go to the FIV to each other or block each one off. Rerouting to eachother works best though.
some of this info is mentioned here on my Skunk2 GSR manifold install:
http://tiiite.ghettoracer.com/tech/sk2manifold/
Old May 8, 2003 | 05:50 PM
MisterB's Avatar
Default Re: GSR throttle body install on ITR manifold (Katman)
thanks for the help...
EFnCRX
Jun 9, 2013 05:37 PM
Freeclowns
Jun 2, 2012 10:37 PM
Sivic87
Jun 13, 2006 08:10 AM
insomniac791
Oct 4, 2003 09:16 PM
SPOON_BeIgHtEeNsEe
Dec 30, 2002 12:05 PM
