please help!!!! code 9 and boggy low end
Old May 3, 2003 | 04:52 PM
88rexdxa6ed's Avatar
Default please help!!!! code 9 and boggy low end
i just put an si motor in my 88 dx and did the mpfi swap. it runs ok but boggy off of idle and throwing a code 9, runs great after 3000 rpm
Old May 4, 2003 | 12:34 PM
Default Re: please help!!!! code 9 and boggy low end (88rexdxa6ed)
does any body know whats causing this?
Old May 4, 2003 | 02:51 PM
ok, i just went got back from driving the car to the gas station, and it rips as long as you don't floor it below 4000 rpm's. and it idles really high when cold around 2000. what could be wrong?????? if you punch it in the low r's it craps out bad
Old May 4, 2003 | 04:18 PM
MONSTERZC's Avatar
the code is the crank angle sensor the distr is bad you have to change the distr b/c nobody make the replacement sensor for it . recheck your wire's at the ecu and the restr box.
Old May 4, 2003 | 08:31 PM
Default Re: please help!!!! code 9 and boggy low end (MONSTERZC)
would a bad distributer cause it to bog low r's and rip in the high rpm? it also seem to be alot faster when cold and not as boggy.
jdmek9imagex
Sep 5, 2009 09:29 PM
JDM_Certified
Jun 30, 2009 08:47 AM
HdmPowered
May 4, 2009 01:41 PM
