FS: NX Nitrous Wet Kit 35 55 or 75 shot tons of extras.
Old May 3, 2003 | 04:40 PM
Chris_'s Avatar
Default FS: NX Nitrous Wet Kit 35 55 or 75 shot tons of extras.
Full NX kit w/ all parts, most assembled and ready to go. tested Leak-free
Fuel pressure safety switch
MSD Window switch with 15-20 RPM pills
N.O.S. bottle heater w/ relay
NX Pressure gauge
Bottle blanket
This is a full nitrous kit from NX this includes *ALL* the parts that came with the kit (solenoids, lines, fittings, bottle, switches, wires, nozzles, jets, and everything else I’m forgetting), even the instruction manual and application sheet! The solenoids and lines are already put together using special thread sealer. You would just need to put the solenoids in place, connect the bottle, and do minor wiring (very simple) and you would be ready to spray! EVERYTHING is included to get you ready within minutes of receipt.
Safety:
NX Fuel Pressure Safety Switch
This switch is used to prevent the flow of nitrous in case of fuel system malfunction. If the pressure drops below 35PSI for any reason (faulty fuel pump, leak in lines, no gas etc..) the nitrous circuit will be cut off. As long as the pressure is at or above 35PSI, everything is fine. This setting is also adjustable.
MSD Window Switch
The main danger with nitrous kits is the issue of engaging the nitrous too soon (could possibly result in nasty backfire) or too late (hitting the rev limiter and damaging the engine). And MSD window switch is called on to allow nitrous flow to ONLY between 2 set RPM’s. These limits are controlled with pills, which are inserted into the main unit. You will receive the MSD switch itself, the necessary relay, a wiring diagram, and around 20 different RPM pills (ranging from 3k to 8k).
Efficiency:
N.O.S. Bottle Heater
Normally and ESPECIALLY on colder days, bottle pressure will be way below the wanted pressure range (900-1200PSI). A bottle heater will raise this bottle pressure by literally heating it with a pad that wraps around the bottle. An increase in temperature of a gas/liquid in a constant volume will increase pressure (the goal). An increase pressure will yield better gains as well as a more efficient use of nitrous and your money. Comes with own relay
Insulated Bottle Blanket
This is a heat-resistant bottle blanket that will keep the bottle temperature constant. It’ll also speed up heat-up times for better performance and efficiency. Finally, it covers scuffed bottles for a cleaner look.
NX Nitrous Pressure Gauge
This gauge comes with all the necessary lines and fittings to be installed in the nitrous system. It can be placed under the engine, in the trunk, or in the driver’s cabin. The gauge will inform the driver of the system pressure, so you can decide to spray or not. Spraying at too low of a pressure won’t get as much power.
selling price is $600 shipped...
or $550.00 picked up with a 3/4 full bottle.
email: stewartc44@hotmail.com
Modified by crxconnection at 6:43 PM 5/8/2003
Old May 3, 2003 | 10:27 PM
Chris_'s Avatar
Default Re: FS: NX Nitrous Wet Kit 35 55 or 75 shot tons of extras. (crxconnection)
blam
Old May 4, 2003 | 10:13 AM
Chris_'s Avatar
up
Old May 4, 2003 | 06:07 PM
untitled's Avatar
tell me about the west michigan honda meet, i am in fort wayne.
Old May 4, 2003 | 09:49 PM
Chris_'s Avatar
Default Re: FS: NX Nitrous Wet Kit 35 55 or 75 shot tons of extras. (88crx91integra)
up up up
Old May 5, 2003 | 02:11 PM
MixdCrix's Avatar
pics?
Old May 8, 2003 | 03:33 PM
Chris_'s Avatar
pics are up
Old May 8, 2003 | 08:44 PM
Chris_'s Avatar
Default Re: (crxconnection)
to the top
Old May 9, 2003 | 09:55 PM
Chris_'s Avatar
up
Old May 10, 2003 | 07:51 AM
baphomet's Avatar
trade for anything?
Old May 12, 2003 | 07:53 AM
Chris_'s Avatar
Default Re: (b3435)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b3435 &raquo;</TD></TR><TR><TD CLASS="quote">trade for anything?</TD></TR></TABLE>
seats maybe... it would depend I really need cash though to get my new motor finished
Old May 12, 2003 | 03:48 PM
baphomet's Avatar
trade for any of this maybe
https://honda-tech.com/zerothread?id=501435
https://honda-tech.com/zerothread?id=501461
https://honda-tech.com/zerothread?id=501468
https://honda-tech.com/zerothread?id=499529
https://honda-tech.com/zerothread?id=499774
if not then bump for you
Old May 13, 2003 | 05:42 AM
Chris_'s Avatar
I unfortunatly dont really need any of those parts... Ill ask around and see if anyone I know needs anything... maybe I could trade you and sell something off to one of my buddies
Old May 13, 2003 | 06:27 AM
baphomet's Avatar
ok thanks
Old May 15, 2003 | 11:09 PM
.RTErnie's Avatar
Default Re: (b3435)
hey I'll take it for 500 a_bruker@hotmail.com email me and we'll work things out.
-Adam
(not me, posting for adam he doesn't have Htech account)
Old May 19, 2003 | 12:20 PM
Chris_'s Avatar
sold....
275Performance
Southeast (Sales)
Jul 19, 2005 07:06 AM
Ken_C
Apr 27, 2005 05:35 PM
TurboT
Nov 9, 2003 04:50 PM
See Are X
Dec 19, 2002 11:55 AM
