Where to find hoses?
Old May 3, 2003 | 03:53 PM
The-LS's Avatar
Default Where to find hoses?
okay I've been to a bunch of local stores and can't seem to find 5/16" water hose. This hose is supposed to go from the outlet near where the upper radiator hose connects to the motor to the back of the motor right below the intake manifold next to the PCV valve. This is coolant bypass hose that came with my AEM CAI I think and bypasses the the coolant that normally runs through the TB.
The hose has a pin hole leak in it now but for some reason I can't find any store that carries this freakin hose. I was just wondering if any of you have suggestion at where else I could look... just in case I'm not thinking clearly now. I was told 5/16" FUEL LINE cannot be used because the hot coolant will break it down prematurely.
Old May 3, 2003 | 04:17 PM
Lord Helmet's Avatar
Default Re: Where to find hoses? (Black-LS)
autozone sells them by the feet and I think pep boys does too.
so I don't know what "local stores" you went to I would've went to these two stores first. common sense.
or honda dealer......not expensive though
CRXSi90
Apr 29, 2014 10:06 AM
dspeedy69
Honda Civic (2001 - 2005)
Feb 25, 2012 04:46 AM
snibbor
Jun 5, 2011 08:58 PM
liquidx
Aug 21, 2010 10:02 AM
R18A1FG
Honda Civic (2006 - 2015)
11
Feb 5, 2007 08:07 PM
