code 23 b16 pre obd ecu
Old May 3, 2003 | 02:32 PM
ILOVEGIRLS's Avatar
Default code 23 b16 pre obd ecu
what is the problem? thanks
Old May 3, 2003 | 06:04 PM
HRTuning's Avatar
Default Re: code 23 b16 pre obd ecu (ILOVEGIRLS)
23 is Knock sensor... What's the full # on the ECU? like PR3-J50... And what motor Euro/JDM/US?
James
Old May 3, 2003 | 06:14 PM
ILOVEGIRLS's Avatar
Default Re: code 23 b16 pre obd ecu (HardLowrdRanger)
its a jdm b16 pr3 with a us gsr motor..thanks
Old May 3, 2003 | 06:37 PM
HRTuning's Avatar
ok... so the knock sensor is connected? If so (I'm guessing the Hassport wiring harness has the correct pin outs to the KS) that means the KS is no good... or is having problems... I used to live in SD... I'm trying to track someone down who can help you out... I'll post back... If you can get another KS and plug it in... just to test... try it out...
Modified by HardLowrdRanger at 3:49 AM 5/4/2003
Old May 4, 2003 | 12:25 PM
ILOVEGIRLS's Avatar
the KS should be working just fine. I just pulled it out of another car that was working just fine. if you can, please find someone for me..it stats and runs...but..
it bogs a little somtimes around 3k rpm...?? it has to be the wiring..
fusedfish12
May 29, 2014 11:18 AM
InEK
20
Apr 10, 2006 09:03 PM
b18cEF9
Jan 25, 2005 03:21 AM
E-brake or Handbrake
May 10, 2004 11:54 PM
TRhatchCRAP
Aug 27, 2003 07:01 AM
