ITR Rear shocks fit in a 00 Civic Coupe?
Old May 3, 2003 | 02:13 PM
rockwilda's Avatar
Default ITR Rear shocks fit in a 00 Civic Coupe?
I know the way the shocks fit in the control arm are the same, but will the shocks bolt up correctly?
tia
Old May 3, 2003 | 02:16 PM
RTW DC2R's Avatar
Default Re: ITR Rear shocks fit in a 00 Civic Coupe? (rockwilda)
I think you just have to use the civic rear LCA and it should bolt right up...
Old May 3, 2003 | 05:21 PM
tecnic1's Avatar
no. I have owned both cars.
Old May 3, 2003 | 05:56 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
short of a welder and a custom control arm, the itr rear shock will not go in a 96-00 civic. sorry.
Old May 3, 2003 | 06:45 PM
jonas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockwilda &raquo;</TD></TR><TR><TD CLASS="quote">I know the way the shocks fit in the control arm are the same</TD></TR></TABLE>
sorry, but they aren't the same. 96+ civics have control arms that need the fork style shock (shock mounting points go around the LCA).
and ITR's have shocks/struts that go inside the LCA.
only on 92-95 civics can you swap in the ITR LCA, but for the 96+ you cant
Old May 4, 2003 | 12:31 AM
rockwilda's Avatar
Default Re: ITR Rear shocks fit in a 00 Civic Coupe? (jonas)
thanks for clearing that up guys, very much appreciated.
Old May 4, 2003 | 12:35 AM
uNF$@#!'s Avatar
Default Re: ITR Rear shocks fit in a 00 Civic Coupe? (CACK ***!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CACK ***! &raquo;</TD></TR><TR><TD CLASS="quote">I think you just have to use the civic rear LCA and it should bolt right up...</TD></TR></TABLE>
B_Swapped93
Sep 25, 2013 09:32 AM
Rocket_Man
Suspension & Brakes
Mar 14, 2013 07:14 PM
OoAoO
May 31, 2008 08:17 PM
Dorikamu
Sep 5, 2002 06:27 PM
PoWeRBaN_PaNdA
Apr 18, 2002 09:31 AM
