JUN springs bind ?
Old May 3, 2003 | 01:44 PM
ScottFern's Avatar
Default JUN springs bind ?
I am trying to do my homework before I put my head back together.
I am running a b18c1 with JUN springs/retainers with skunk2 stage 2 cams.
I have heard bout how everyone says I should get ITR Lost Motion Assemblies to insure the cams do not snap. Also, my friend installed the jun springs and retainers, should I be worried about clearance, and take it to a machine shop and have them look at it, too make sure it won't bind the spring ??
What other measure should I take to insure that my setup is all set to spec ???
Old May 3, 2003 | 09:48 PM
ScottFern's Avatar
Default Re: JUN springs bind ? (ScottFern)
anyone have this problem ?
Skunk2 Stage 2 12.3 mm(intake lift) 266 @ 1mm 11.8 mm (exhaust lift)
JUN Springs
12mm 195lbs
12.5mm bind
**1.340 installed height
This won't work ???
Modified by ScottFern at 9:18 AM 5/4/2003
Old May 4, 2003 | 07:18 AM
NSX Bob's Avatar
New User
For my $, I would (and did) get Toda valve springs, although I am running a Toda package. Nonetheless, you can use them w/ Jun's or Skunk's cams.
Old May 4, 2003 | 07:41 AM
advanracing62's Avatar
Default Re: JUN springs bind ? (Type R Bob)
I've been running my JUN III head now for about 8 months. No complaints, I've checked the springs a coulple of times while performing valve adjustments. Everythying looks OK. I know that SGT. has issues with the JUN springs though.
HKSone
10
Mar 1, 2005 03:47 AM
ScottFern
May 5, 2003 08:27 AM
AllMotorITR
Mar 8, 2002 06:13 AM
People_Mover
Feb 25, 2002 08:18 AM
