GSR vs ITR bump stops
Old May 3, 2003 | 01:27 PM
shingles's Avatar
Default GSR vs ITR bump stops
I am curious if bump stops on the two are different? I am installing a set of ITR springs and struts but am having to use some GSR hardware(including the bump stops). Should I trim the GSR ones?
thanks,
-Shing
Old May 3, 2003 | 01:37 PM
VTECorona's Avatar
Default Re: GSR vs ITR bump stops (shingles)
I highly doubt they are different in size. The R only sits slightly lower than the GSR. You can get away with gsr ones
Old May 3, 2003 | 02:13 PM
shingles's Avatar
Default Re: GSR vs ITR bump stops (97RedTegGSR)
man the r sping looks a good bit shorter than the gsr, atleast the 4 door gsr.
Old May 3, 2003 | 02:22 PM
VTECorona's Avatar
I have never seen the two compared but I don't see why they would bother using 2 different sizes when the ride height is only slightly different. Chop off the very top part of the gsr bumpstop if anything.
ek92
Northwest (Sales)
Mar 17, 2009 02:40 PM
SiR AuToBoT
Apr 18, 2005 12:41 PM
JdMjOhNyO
Nov 30, 2004 12:27 PM
shingles
May 3, 2003 01:32 PM
bundy
Dec 2, 2002 01:40 PM
