ZC Build Up
Old May 3, 2003 | 11:15 AM
89civichatchback's Avatar
Default ZC Build Up
Ok i have a budget of prolly $1500. And im wanting to build my DOHC ZC for N/A. What kind of parts should I get and where should I get them at? Help me out people. Thanks
Old May 4, 2003 | 04:42 PM
MONSTERZC's Avatar
Default Re: ZC Build Up (89civichatchback)
you can get cam's i like web cams high comp pistion's eagle rods. you can mill the head 0.4mm to get higher comp ratio of 10.0.1
Old May 4, 2003 | 06:26 PM
boosted_zc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC &raquo;</TD></TR><TR><TD CLASS="quote">you can get cam's i like web cams high comp pistion's eagle rods. you can mill the head 0.4mm to get higher comp ratio of 10.0.1 </TD></TR></TABLE> That's definately the way i'd go with an NA setup. the pistons and rods are gonna be ur biggest drop of cash, probably between 700-800 dollars. The cam regrinds aren't priced bad at all, i think there 150 -180 each cam. After that, IHE and you'll be running pretty damn good.
Old May 4, 2003 | 09:34 PM
redzcstandardhatch's Avatar
something different
Default Re: ZC Build Up (boosted_zc)
ive read you can mill the zc up to 1.4 mil. i hope this is true, if so, you should get about 10.6;1 comp. ratio......anyone done it? i thoughti read last week somone had
Old May 4, 2003 | 11:13 PM
'90 ZC REX's Avatar
Default Re: ZC Build Up (redzcstandardhatch)
You read right....My ZC Head is milled 1.4mm. I am also running a set of ZC Brothers Stage 2 Cams, with no problems. If you have any questions regarding the ZC, I have pretty much done everything NA Wise you can do to it.
Later
Mike
'88 CRX DX "ZC REX"
'99 S-10 Xtreme
Old May 5, 2003 | 10:36 AM
MixdCrix's Avatar
Where are the cams from? Hitme up- I got some questions on my set up so hit me up?
Imd u-88...
grandtheftlunchbox
Mar 30, 2008 09:14 PM
Grandhustleman86
14
Jan 20, 2007 01:14 PM
JK_Motorsports
Nov 24, 2005 06:09 PM
redzcstandardhatch
74
Dec 15, 2003 08:17 PM
killercrx
11
Oct 18, 2001 09:57 PM
