-- Weight differences between different year crx's, Why? --
Old May 3, 2003 | 09:48 AM
WickidSi's Avatar
Default -- Weight differences between different year crx's, Why? --
I was just curious as to why the 88 crx is the lightest and then each year gets heavier? I am mostly refering to the si. I know the 90-91 had side inpact beams in the doors, But what else cause the ~150lbs. weight difference?
Thanks
Old May 3, 2003 | 09:55 AM
FourthGenHatch's Avatar
Default Re: -- Weight differences between different year crx's, Why? -- (WickidSi)
More features in it I guess.
Old May 3, 2003 | 10:03 AM
matt j's Avatar
Default Re: -- Weight differences between different year crx's, Why? -- (FourthGenHatch)
in the 88s the seatbelts were mounted on the b-pillar (i think thats what its called) in 89-91 they put the seatbelts on the doors. in 90-91 they put a steel beam in the door to help with safety issues.
Old May 3, 2003 | 10:53 AM
Vinceg99's Avatar
Default Re: -- Weight differences between different year crx's, Why? -- (mattED6)
There are also differences with more or less sound deadening material in each year and in each model. Well plus the features as someone stated above like the Si model will be heavier cause of the sunroof. Oh and also some 89's did have the pillar mount seatbelts as well I believe just the HF's? And also in Canada I dont think even the 90-91's have the door maounted seatbelts?
Old May 3, 2003 | 12:34 PM
blah13's Avatar
Default Re: -- Weight differences between different year crx's, Why? -- (Vinceg99)
Si's also have rear disc.
Old May 3, 2003 | 01:01 PM
4door_gsr_ftw's Avatar
There's probably more smog emissions on the car, too.
scottmog
11
Aug 29, 2009 09:03 AM
undercoversi
Nov 15, 2005 08:54 AM
julian_gq
Mar 31, 2005 09:46 PM
dropd4door
28
Dec 18, 2002 08:21 PM
chasrex
May 16, 2002 01:53 PM
