oil on plugs seat
Old May 3, 2003 | 08:35 AM
alexus's Avatar
Default oil on plugs seat
I have a 94 honda accord and when I change the number 2 plugs yesterday I noticed alot of oil where the plug seats. The oil is not where the plugs burn the fuel. The tips of the plugs are in excellent condition very white with no fouling. Where is this oil coming from? Thanks
Old May 3, 2003 | 08:46 AM
H22 CD5's Avatar
the oil is coming from the spark plug hole grommets that sit on the underside of the valve cover.chances are, you have one that's cracked/worn.have all 4 changed out along with the valve cover gasket.
Old May 3, 2003 | 10:04 AM
Razor's Avatar
Default Re: oil on plugs seat (alexus)
did you overfill the oil during your last oil change?
Old May 3, 2003 | 10:28 AM
alexus's Avatar
Thanks for h22 cds I will try that.
Razor I did not overfill the oil. I think it was 1/2 quart less
Old May 3, 2003 | 10:35 AM
D114's Avatar
Default Re: (alexus)
He's right. also check your PCV valve. It's an easy check, and if its broken, it'll cause oil to shoot right thru the seals.
Old May 3, 2003 | 01:38 PM
H22 CD5's Avatar
doh! i totally forgot about the pcv. Somethin else to take into consideration....you stated that your spark plug electrodes are "very white". that indicates a lean burning condition in your combustion chamber. Have your fuel system checked. when's the last time you've had your fuel filter/pump changed?also, check your ignition timing to see if it's not too advanced.
Old May 3, 2003 | 03:55 PM
alexus's Avatar
Thanks again for everything h22cds and d114.
Anyone recommend where I should get this gasket kit. Any good brand or just napa.
cjwang2
Sep 30, 2015 10:17 AM
smetzger
Mar 31, 2008 10:15 AM
VtecDA9
Apr 5, 2004 11:17 AM
sacredc0w69
May 24, 2003 06:34 AM
eastsidemags
Mar 22, 2002 01:22 PM
