a/c question
Old May 3, 2003 | 08:18 AM
frank5079's Avatar
Default a/c question
I have an '87 Integra motor swap in my '84 CRX. Last summer I had to wire my a/c compressor directly and used another a/c switch to make the whole thing work; my problem is the engine idle. With the a/c off, it idles fine. Turn it on and the engine dies. I was going to use the a/c idle vacuum switch from a first gen Si, but I can't attach the vacuum actuator attachment to the teg throttle assembly.
I've heard that the teg uses a signal from the ECU to raise the idle when the a/c is on. Which wire is it and can I just splice a wire from my a/c switch to the ECU??
Thanks in advance,
Frank
b16_sol_707
Engine Management and Tuning
Oct 15, 2008 07:07 PM
tigueremalo
Mar 3, 2006 03:04 PM
