Wich ecu to use
Old May 3, 2003 | 08:17 AM
greenli0n25's Avatar
Default Wich ecu to use
I already have a jdm P13. Should I get the P13 chipped or should I get a P28 chipped ? I have heard there is a lot more restrictions with the P13 is this gona be an issue or should I just use a P28 or any other ecu recomended
Modified by greenli0n24 at 5:48 PM 5/3/2003
Old May 3, 2003 | 10:12 AM
lazy bum shaughn's Avatar
Default Re: Wich ecu to use (greenli0n24)
I'm assuming you have an H22 motor. I hear chipped P72s are good to chip.
Old May 3, 2003 | 10:51 AM
Kris's Avatar
Default Re: Wich ecu to use (lazy bum shaughn)
I have heard that chipped P28's work with that motor.
Old May 3, 2003 | 11:57 AM
eg6ajk's Avatar
Spoon chipped P13 by far best you can do. especially since H22a requires secondary activation.
p28 will work but only with proper program otherwise you'll be making less power.
only thing with the P13 is the EGR which can slightly make it harder to wire.
Old May 4, 2003 | 08:21 PM
yeah its a 99 usdm h22 but im converting it to obd1 and I have a jdm P13 but not sure wich Ecu and program to use yet
mike541
Mar 14, 2011 09:03 PM
jays01
Engine Management and Tuning
Feb 6, 2009 07:35 AM
Got Milk
Jun 7, 2005 10:28 AM
O RLY
Oct 5, 2004 10:42 PM
p10hlm
Nov 9, 2002 10:47 AM
