are all d series oil pan the same??
Old May 2, 2003 | 09:09 PM
JCracer723's Avatar
Default are all d series oil pan the same??
im wonderin if a a6 oil pan is the same to a z6 oil pan .. any1??
Old May 3, 2003 | 05:25 AM
DJ_SaNdOz's Avatar
Default Re: are all d series oil pan the same?? (JCracer723)
i'm pretty sure they are the same. i bought a new one & i know for sure that teh gasket was for all civics like 88-00 or something, and i'm pretty sure the pan was the same.
Old May 3, 2003 | 06:58 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: are all d series oil pan the same?? (dj_sandoz)
yes it will work, they all will
Old May 3, 2003 | 12:11 PM
JCracer723's Avatar
Default Re: are all d series oil pan the same?? (Y49CRXSIZC)
yeah i was kinda wonderin since they have diff part numbers
Old May 3, 2003 | 01:00 PM
EG8R's Avatar
I wouldn't mind gettin an alumimun pan from a Y8....
Old May 3, 2003 | 01:33 PM
JCracer723's Avatar
Default Re: are all d series oil pan the same?? (mr. skelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. skelly &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't mind gettin an alumimun pan from a Y8....</TD></TR></TABLE>
aluminum eh? hmm interestin
Old May 3, 2003 | 04:25 PM
seekerONE's Avatar
88-95 pans CAN be interchanged....96-00 Can only be used on 96-2000...slightly different bolt pattern due to different oil pump. BTW the aluminum oil pan(Y8)is heavy and expensive
Old May 3, 2003 | 06:29 PM
civicwagonman's Avatar
Default Re: (seekerONE)
most people won't need this info but the rt-4wd wagon has a different pan, infact, the 2wd wagon has the same pan. its clearanced for the transfer case.
Old Jun 6, 2003 | 10:37 AM
JCracer723's Avatar
Default Re: (civicwagonman)
yes the y8 pan is diff than th a6 pan didnt fit.
is any1 out there using the a6 pan on their z6???
b17a1teg
Mar 30, 2011 02:18 PM
silverboost
Jan 18, 2006 09:19 PM
TheShocker
Feb 29, 2004 10:58 PM
