ENDYN Rollerwave pistons,rings,wristpins $465 shipped NEW
you still got those eagle rods for sale, if so, i would like some pics. email me at faraj77@aol.com, thanks
hello. Correct me if I am wrong. Compression ratio of a piston never changes. The compression ratio of your engine and set up may vary and change. But the piston is designed from the manufacturer to be a certain compression ratio based on stock applications. So technically, the simple compression ratio of a piston can be stated as being a solid number.
The dome of the piston does not change. When that piston is placed into a different block/motor, the compression will change. There is a standard number for the compression for b16/b18c1/b18c5, you could contact endyn, or VS racing (where they pistons were purchased for over 500) for exact compression numbers
stand corrected.
stand corrected.
