cluster questions
has anyone seen this before. using an integra cluster in a civic. i was going to buy an si cluster but they are around 300. would this be worth looking into?
http://cgi.ebay.com/ebaymotors...33675
this add looks more like taking bothe clusters apart and putting one back together. can you actually take an integra cluster and pop it right into the civic dash? what about the clips on the back, do they mach up?
THIS IS THE ACTUALL ADD
auction is for the proper instructions you will need to install a 94-01 Integra GS, LS, or GSR (GS-R) instrument Cluster into your 96-00 Civic or 99-00 Civic Si!!
You get the following:
1. My very own conversion chart and installation instructions complete with pictures!
2. My very own detailed picture laden instruction set, written by me, that I made as I did this conversion on my 1998 civic ex.
4. 3.5" floppy diskette with my instructions in color just in case you get confused by the black and white printed version I provide (for easy lap reference while in the car of course).
You can re-use your Civic harness plugs when installing the integra cluster into your dash but having a second set makes it sooo much easier. However, all you really need is to follow my instructions and use my chart to cross the wires!!
Please note that you will be required to swap two wires on your SRS connector for proper funtion (cutting and splicing them real quick, yellow plug). Also, if you have cruise control you will have to cut an extra wire to get the cruise working properly. However, this is the ONLY splicing you will need to do and they come from non-essential "extra" plugs that are left over!
This is a wonderful, simple, original, and cheap upgrade for your Civic as opposed to going with a JDM or SI cluster. Just run a search on the cluster prices on here...it's unbelievable what they are going for compared to the integra clusters!
I recommend the following clusters for your car in order to keep the proper RPM redline intact:
96-00 Civic DX/LX/EX = 94-01 Integra GS/LS
99-00 Civic SI = 94-01 Integra GSR
Here's an interesting and WONDERFUL side effect from this installation that I found as I was making my chart and doing the installation....If you follow my chart 100% you will have between 1-3 extra sets of power, ground, and headlight switch leads. what does this mean to you?? Well how about easily accessible power, ground, and headlight source wires for installation of your aftermarket gauges in the A-pillar?? That's right!! no more tapping lines and risking circuit overload and frying the wires!! now your gauges will have a dedicated circuit of their own which will be EASY to access from the A-Pillar, NICE!!!
*NOTE*This is for manual transmission cars only!! I did not get the necessary wiring section for the integra (I already had the codes for the civic and they are on the chart but you will have to find the integra codes yourself if you want to do auto conversion). This is because I had a stick-shift car and didn't need/want this info.
buyer pays $2.00 shipping/handling (that's right! only 2 bucks...it is after all only an instruction set and floppy disk...I'm not here to rip you on shipping like some people!!!).
I only accept paypal for this auction, thanks!
Picture provided of the 1995 integra GS instrument cluster I personally installed in my 1998 Civic Ex after I designed my chart and using it! As you can see, it looks beautiful and like it belongs there...WITH NO GAPS!
jdmcivicferio
Sep 22, 2003 07:21 AM
JDM-FREAK
Feb 7, 2002 07:17 PM
