High lift cams in gsr w/ CTR pistons...
Old Jul 3, 2001 | 03:48 PM
adamp35's Avatar
New User
Default High lift cams in gsr w/ CTR pistons...
I have a '95 j-spec GSR with CTR pistons. I have plans in the future of complete headwork, port, polish, 3 angle valve job... everything! Well I guess my concern is running a high lift cam with the CTR's. The piston has the valve releifs in it, and I would assume it would be ok with just about any cam. But what about the cam gears. When you start retarding or advancing the cams. Will there be valve clearance issues. Also if anyone could rccomend a good head builder. My goal is to be around 225 whp in the end, and streetable. I know it can be done, and I am willing to drop the cash. I just need to know what is going to work??
I appreciate all replies..
Thanks
ADAM
PRES. NATURAL DISASTERS (all naturally aspirated hybrids)
Old Jul 3, 2001 | 05:44 PM
NegativeLift's Avatar
Default Re: High lift cams in gsr w/ CTR pistons... (adamp35)
try posting this in the ITR forum
Old Jul 3, 2001 | 08:45 PM
FSTASNTZ's Avatar
As long as you do not mill the head or deck the block, you should be fine. I know people are running that setup with TODA Spec C cams with no problems. I will be running a similar setup in a few weeks.
Jason
Old Jul 4, 2001 | 10:27 PM
AJ PwR's Avatar
With your similar set up Spoon cams will make about 210-220 whp and 140-150 lbs of torque.
Spoon it dude!!!!
Old Jul 6, 2001 | 11:15 AM
FAST94GSR's Avatar
New User
How's your car running now with those pistons? Any detonation? Just make sure you have enough valve clearance using the clay method to check. I'm thinkin bout goin with ctr pistons.
Old Jul 6, 2001 | 11:39 PM
AJ PwR's Avatar
Default Re: High lift cams in gsr w/ CTR pistons... (FAST94GSR)
I think he must be running with a thicker head gasket or B16 head. GS-R running with CTR pistons CR will probably hit up to or pass 13:1 . I will suggest ppl to buy JDM ITR pistons (CR11.6:1 installed to GSR) more safer and durable.
Old Jul 6, 2001 | 11:52 PM
RTEK's Avatar
New User
High lift cams will collide w/ CTR pistons GUARANTEED ( unless u enlarge the pocket ) engine building steps....
check out the best in head building http://www.bceracing.com and then ask for bill craddock
note they built the VENOM CIVIC HEAD
Old Jul 7, 2001 | 01:06 AM
adamp35's Avatar
New User
Default Re: High lift cams in gsr w/ CTR pistons... (AJ PwR)
I am running the stock honda "p72" head gasket (gsr gasket). I am not having detonation at all on 92 octane! I polished by combustion chambers before I put the motor back together. As For running ctr's in the gsr, I am happy with the result. I also have answered my own question by asking around. I know that ctr's will work with any aftermarket cam. But turning the cam gears is where you get into trouble. I asked the guys at superior racing developmant what they thaught, and Joe told me this...
We have two cars here with ctr pistons installed. One has jun cams, the other has crower's. Both cars are in the 12's all motor. They also are using the STOCK cam gears!! So there is the answer. Stock cam gears are the best when running high lift cams with ctr's.
Thanks for all of you replies,
ADAM
PRES. Natural Disasters (all naturally aspirated hybrids)
uhhmaysing
May 13, 2014 08:11 AM
shandonwall
18
May 29, 2009 05:35 AM
_HANS
39
Jan 4, 2009 01:22 AM
civic1320
Jul 24, 2003 11:33 PM
stretracr
Jun 26, 2001 06:16 PM
