B17A1 YS1 tranny w/LSD
Old May 2, 2003 | 12:06 PM
Hondasaurs's Avatar
Default B17A1 YS1 tranny w/LSD
Is there a way to tell if the tranny has an LSD (a stamp or something on the sticker)? I was doing some research on the B17A1. I found out that the 92-93 GSR had this option.
Old May 2, 2003 | 01:28 PM
PupaScoopa's Avatar
Default Re: B17A1 YS1 tranny w/LSD (ZC_CRX)
The typical rule of thumb is to look through where the axle shaft go into the transmission. If you can see all the way though the hole, you have an LSD. If there's a bar or something in the way, it's an open diff.
Old May 2, 2003 | 01:38 PM
chet's Avatar
Default Re: B17A1 YS1 tranny w/LSD (PupaScoopa)
the 92-93 USDM gsr's did not come with LSD.
and i don't believe it was ever an option.
Old May 2, 2003 | 04:44 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZC_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way to tell if the tranny has an LSD (a stamp or something on the sticker)? I was doing some research on the B17A1. I found out that the 92-93 GSR had this option.</TD></TR></TABLE>
here's some info on LSD ID'ing...
http://tiiite.ghettoracer.com/LSDcheck!.htm
fyi, none of the US 92-93 GSR's had an optional LSD equipped tranny...only in Japan they had this option. If you came up on a YS1 tranny w/LSD its more than likely a JDM tranny from a 92-93 XSi/RSi DA Integra.
Old May 2, 2003 | 06:03 PM
chet's Avatar
Default Re: B17A1 YS1 tranny w/LSD (Katman)
great information katman
crzyfool24
24
Apr 2, 2004 10:33 PM
wizzards581
Aug 20, 2003 02:38 PM
Aids333
Aug 20, 2003 07:49 AM
CRX A4
Apr 5, 2003 04:04 AM
Nextelbuddy
Mar 31, 2003 07:40 PM
