clutch installation + spare parts to buy
My Acura 2.2 CL 5spd has 95k.
I just received my Clutchmasters/Fidanza flywheel from Kteller8
I have a ACT Heavy Duty pressure plate and Performance Street disk.
What other parts besides the T/O bearing would I need? Pilot bearing? (if so, how much?)
Also another question. I am pulling out the engine+trans so I can do the timing belt and water pump; Is it adviseable to change the head-gasket as well?
You might want a clutch alignment tool.
No pilot bearing on our cars.
I would NOT change the head gasket.
You'll need 3 quarts of honda MTF and some of their "super high temp urea" grease for the release fork, the slave cylinder pivots, clutch splines, and mainshaft/ TO bearing interface.
Dont forget the brake fluid.
Might change the fuel filter while the engine is out.
(and dont forget the Quaife).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niedejb »</TD></TR><TR><TD CLASS="quote">You might want a clutch alignment tool.
(and dont forget the Quaife).</TD></TR></TABLE>
Do you mean just the cl, or do all hondas have no pilot bearing? I just received my h22 flywheel and am going to do it in about a week.
The h and the f share the same flywheel and they have no pilot bearing (bearing between the flywheel and the mainshaft of the tranny...all we have is a little pressed in bushing).
On the other hand they both have throw out bearings (bearing between shift fork and pressure plate fingers).
Mt3c
Sep 10, 2003 03:12 PM
