OT: Chicago People I need Help on Where to Buy Supplies!
Where can I buy some good quality brake fluid in the Chicago area? What would you reccomend for a Type-R that sees some track use but not a ton. I also need a speed bleeder. Where can I get one!?
Thanks!
Thanks!
I've used Motul and it's worked fine.
I haven't used speed bleeders, and I never bleed my brakes (although I flush fluid at the start of every track season). I haven't had brakes fade or boiled my fluid in a long time, though. My brake heat problems are usually manifest as shudder (from "hot spots") and/or cracked rotors. Must be the Motul.
A friend of mine swears by Speedbleeders. And a different friend says that Pepboys carries them although I've never gone to look for them so I can't confirm.
carblegal
41
May 4, 2003 09:28 AM
