nitrous on b16
Old May 2, 2003 | 05:50 AM
Rob!'s Avatar
Default nitrous on b16
hey guys im thinkin of gettin a nitrous kit...i dont wanna use it a lot. i dont have anything built in my motor just stock b16 with intake and exhaust. i really only plan to use it VERY little just until i get turbo at the end of the summer. anyone have this setup? a friend is selling a zex kit for VERY cheap and i dont know how bad ill be ruining my motor if i use it not often at all.
Old May 2, 2003 | 06:56 AM
madman13lm's Avatar
Nice avatar!!!
Umm... I too have a B16 rex and would like to know what kind of shot can be run safely on a stock block.
Old May 2, 2003 | 06:58 AM
JoshDM's Avatar
Default Re: (madman13lm)
the zex is a good kit for beginners.
you can run a 75 dry shot safely on a stock block.
Old May 2, 2003 | 09:27 AM
ThatRicerDaniel's Avatar
Default Re: nitrous on b16 (b16hf)
Zex / NOS
Old May 2, 2003 | 09:40 AM
91sleeper's Avatar
Default Re: nitrous on b16 (NitrousDreamz)
nitrous
Old May 2, 2003 | 09:43 AM
madman13lm's Avatar
I was personally thinking of this kit. http://www.nitrousexpress.com/...33303
Old May 2, 2003 | 09:49 AM
Blaze45's Avatar
Brrraaaap!
run colder plugs bigger fuel pump injectors fpr and some kind of fuel management
Blaze
Old May 2, 2003 | 09:50 AM
madman13lm's Avatar
Default Re: nitrous on b16 (91sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sleeper &raquo;</TD></TR><TR><TD CLASS="quote">nitrous
whats wrong with nitrous?
Old May 2, 2003 | 09:56 AM
Rob!'s Avatar
Default Re: nitrous on b16 (madman13lm)
yes the kit is a zex 75 dry shot with purge....wants 300...should i take it??? i know nothing about nitrous
Old May 2, 2003 | 09:57 AM
Rob!'s Avatar
and how hard is it to install?
Old May 2, 2003 | 01:42 PM
civickiller's Avatar
i think 75 shot is alot, i would run a 50hot just to be safe, idk if 75 shot is safe on stock
Old May 2, 2003 | 02:12 PM
reese's Avatar
Default Re: nitrous on b16 (civickiller)
75 shot dry is to much for a stock b16
Old May 2, 2003 | 02:36 PM
Rob!'s Avatar
Default Re: nitrous on b16 (reese)
the shot is adjustable from 50-75....i would probably run 55shot....but im seriously not going to use it nearly as much as u guys think
Old May 2, 2003 | 03:09 PM
TRE_'s Avatar
i'm running a wet, 60 shot (nitrous oxide systems) on my basically stock zc. i bumped up the fuel pressure with a b &m command flo, retard the timing a couple degrees and dropped some colder plugs in and its ran perfect. the install is fairly straight forward. most time consuming part is running all the wiring. NOS or NX would be my first choices as far as brands, and a wet system seems safest to me. With a wet kit and a few simple mods(timing, plugs, FPR), you should be able to run a 60-75 shot just fine.
Old May 2, 2003 | 03:20 PM
bryant's Avatar
Default Re: (glowing_rotors)
With wet you should be able to run At Least a 75 shot on a stock b16, Just do the normal crap. (retard timming, colder plugs, more fuel, that kinda stuff) and your set. Dont be a *****
Old May 2, 2003 | 04:41 PM
SiR831's Avatar
Default Re: (Bryant)
nitrous express and NOS
Old May 2, 2003 | 07:22 PM
1RMDave's Avatar
Default Re: (SiR831)
i had a zex kit on my b16 for two years and ran a 75 shot. It never had a problem, just had to retard the timing and get colder plugs.
Old May 2, 2003 | 08:45 PM
smokey2.0's Avatar
what 1/4 mile times, are you guys getting using a 50 and 75 shot?
Old May 3, 2003 | 12:15 PM
Rob!'s Avatar
Default Re: (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">what 1/4 mile times, are you guys getting using a 50 and 75 shot?</TD></TR></TABLE>
id like to know as well
Old May 3, 2003 | 04:01 PM
Swift's Avatar
Personally I would not pay more than 250 for used a zex kit. Of course this is only my opinion. Also imo the nitrous express selenoids are better than those in the nos kit.
Old May 13, 2003 | 03:27 PM
ZetecOwns's Avatar
Hmmm....didnt you say this on another thread I was just on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sleeper &raquo;</TD></TR><TR><TD CLASS="quote">people are narrow mined and need to realize that its not there car, they dont have to drive it so they shouldnt worry about it
I guess people are only narrowminded when they dont share YOUR views, right?
How about its not your car, so don't worry about it!
bam_89
10
Jul 30, 2008 12:54 AM
mattb145
Mar 1, 2007 12:45 AM
egb18c5
Jan 22, 2007 11:03 AM
4ghatch
Jul 14, 2004 07:59 PM
CarAudiophile
Jun 11, 2004 10:21 AM
