Intercooler Mounting....Are You Bolting It Up
I have beautiful PWR intercooler that I bought from nineseccrx (Great Seller by the way) and I am wanting to know how some of you are mounting your custom intercoolers. Are you guys having brackets welded on then bolting them to the chassis brace or somewhere else? Just wanting to get some ideas on the best way to mount this thing. I just don't feel safe using only the intercooler pipes. If you have pictures of your custom mounting, I would like to see.
This is on a 92 Civic Si by the way.
Thanks in advance.
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR »</TD></TR><TR><TD CLASS="quote">i lined mine up where i wanted it to fit and then i used a drill to create holes and then i used screws with a nut on each end
Got pics? Where did you drill?
</TD></TR></TABLE>Got pics? Where did you drill?
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Here are some of the things that I did. The top of the intercooler came with tabs, and as you can see in the pics, I made some (a friend) made some little holders to support the intercooler and welded it to my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafu-Si »</TD></TR><TR><TD CLASS="quote">Here are some of the things that I did. The top of the intercooler came with tabs, and as you can see in the pics, I made some (a friend) made some little holders to support the intercooler and welded it to my car.
damn..thats badass
damn..thats badass
Mine is bolted to the bumper support with brackets made out of flatbar(bumper support was cut beforehand to fit my bumper, then the bumper was later trimmed to fit the ic).
I had 2 aluminum cylinders welded to the top of the IC to match the two holes in the bumper support, slipped bolts throught the top of the holes and tightened it down. Works awesome.
That is smart thinkin though
I removed the front cross member all together, and welded support brackets on the bottom of the intercooler to catch the lower frame. I used the two tabs that were already welded onto the top of the intercooler and make special brackets that went through existing bumper support holes.
... looks sweet!!!... got more pics?... maybe from the front?... anyways,
i mounted mine to my bumper support, i had brackets welded to the ic, and then underneath it we made some other custom brackets to pull it closer to the car at the bottom . . . . not as nice as above though
That looks real nice, but you know if you ever get into a front end accident, you can kiss your i/c , turbo, manifold all good bye depending on how hard the impact is because the purpose of that front bumper support that you took off is to protect you from front end collisions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kimbo »</TD></TR><TR><TD CLASS="quote">That looks real nice, but you know if you ever get into a front end accident, you can kiss your i/c , turbo, manifold all good bye depending on how hard the impact is because the purpose of that front bumper support that you took off is to protect you from front end collisions.</TD></TR></TABLE>
Jee, I never thought of that. Never. Ever. You mean the intercooler wont protect the whole car? Its a race car, i never drive it, ever, never
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE »</TD></TR><TR><TD CLASS="quote">
He speaks the truth. He towed his car to the NE honda-tech meet.
</TD></TR></TABLE>He speaks the truth. He towed his car to the NE honda-tech meet.
trooper0641
Sep 25, 2004 11:46 PM
dohc-nyne
Dec 19, 2003 10:04 AM
