lots of B,D,H,F series and performance parts
.22 x 8 - 15 Mickey Thompson Drag Slicks only used in two events. they come with 15" 5star mugen looking wheels which are painted flat black. $300
MEZIERE Elec Water Pump Kit !!!BrandNew!!! (5+HP gains from 0 to max RPM) B-Series VTEC Kit. $300
GSR ECU OBD1(94-95) P72 $300
GSR OEM Valves excellent condition, no damage $5each (vs. $16new)
AIR BAG Sets from 95 GSR's. Black Set, Charcoal Set. $100per set
95 GSR Rods 50K. Perfect Condition $50
94 B16 Rods 40K Perfect condition $50
98 GSR Power Steering Pump (this pump is needed for 6g B-series Hybrids) only14K $100
94+ Integra Full Size Dual Core Radiator Mint, less than 1000miles and comes with both fans. $125
94 B16 Crank Mint $125 add $40 for professionally micro polishing bearing surfaces
Darton Sleeved 94 H22 Block and Endyn Low Compression Pistons ((((90mm bore))) Email for more info. NO crank or rods
98 Prelude Alternator 20k w/Unorthodox underdrive pulley. $125
96 Accord VTEC Distributor 48K. $125
97 F22b1 SOHC VTEC 40k. Longblock ONLY. NO tranny or ECU. $350
OEM 97 Prelude Axles ??mileage but in excellent condition. Very tight. $150
H23 Crank Mint $150 add: $40 for professionally micro polished bearing surfaces
91 Si ECU w/PYR Chip $185
91 Si Distributer $100
91 Si Alternator $65
91 Si Complete intake $65
92-95 Si Starter $50
