what is the compression with ctr pistons in my b16
Old May 2, 2003 | 12:21 AM
riceball777's Avatar
Default what is the compression with ctr pistons in my b16
what is the highest compression u guys recomend on pump gas. (91 octane)
how much hp and torque increase can i expect with ctr pistons?
Old May 2, 2003 | 12:43 AM
Default Re: what is the compression with ctr pistons in my b16 (riceball777)
anyone know?
Old May 2, 2003 | 12:50 AM
10K2HVN's Avatar
Well i got 10.801068956759683:1 cr with OEM gasket at http://www.c-speedracing.com ..but people say its higher because c-speed doesnt take something into the equation...
Old May 5, 2003 | 09:04 PM
Damon's Avatar
on average, 11.1:1
Old May 5, 2003 | 09:11 PM
allm0torGSR's Avatar
Default Re: (Damon)
this page is dope!
http://www.bojangs.com/calculator/
Unless you really know what your doing as far as tuning goes, I wouldn't go past 11:1 CR on pump gas, to stay on the safe side.
Old May 6, 2003 | 06:04 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re:
It will be 10.8:1 assuming you get stock bore 81mm pistons, stock valves, stock headgasket, unmilled head etc... If you go with 81.50mm pistons, flat valves, milled head and thinner head gasket you could be pushing high 11's. B16B has 10.8:1 with no differnce then a stock B16A other then internal parts.
rex89sir2
Apr 23, 2008 06:30 AM
speedracer209
Aug 17, 2006 01:10 AM
Spyderman4g63
Apr 27, 2005 01:23 PM
EFing8
10
Dec 14, 2002 04:00 PM
CanadaCivic
Nov 15, 2002 01:46 PM
