need help.. what distributer do i use on my dx with si motor?
Old May 1, 2003 | 11:22 PM
88rexdxa6ed's Avatar
Default need help.. what distributer do i use on my dx with si motor?
i just put my si motor in my 88 dx and i need to know with dist. i need to use. is it possible to keep the si dizzy? i think the one on the dx was messed up any way. also does anybody know a good cam grind from delt cams?
Old May 2, 2003 | 02:51 AM
civickiller's Avatar
Default Re: need help.. what distributer do i use on my dx with si motor? (88rexdx)
if your using the si motor, u gotta use the si dizzy too, dx wont work
Old May 2, 2003 | 06:47 AM
white99gsr's Avatar
Default Re: need help.. what distributer do i use on my dx with si motor? (civickiller)
what year is the motor? if it's a 92-up si motor than no you can't use the distributor you have because it's OBD1 and the car is pre-OBD, unless you do a OBD0-OBD1 coversion. the dx won't work either because it's not made for mpfi and has no crank angle sensor. you need to get a 88-91 si/hf/ex distributor.
efboy
Mar 6, 2005 06:59 PM
Agent Daimon
Dec 17, 2002 03:42 AM
Red_Si
12
Sep 4, 2002 12:07 PM
simike
Aug 13, 2002 02:50 PM
Red_Si
Jul 5, 2002 04:57 AM
