WTB: LS Stuff! List inside!
WTB the following items: ALL ITEMS ARE FOR 92 INTEGRA LS (unless otherwise noted)
P75 obd1 ECU - No Longer Needed - thanks not so civic
LS Axles
94+ integra motor mounts - No Longer Needed - thanks b18c1_powered_si
Clutch
Flywheel - No Longer Needed - thanks b18c1_powered_si
Distributor
Shift Linkage
I don't care if you go to a junkyard and get this ****, MAKE SOME QUICK CASH, HOOK ME UP!!!
Modified by OnePointFive at 6:09 AM 5/2/2003
LS Axles
Clutch
Distributor
Shift Linkage
I have a OBD-1 ls dizzy that works fine except I cut the plugs to make it work on a OBD0 car. I still have the plugs for it and will put them back on with soldered connections and will get rid of this for cheap if interested. Please let me know.
Hoppa
Jul 25, 2006 05:20 PM
