Er more questions about valve adjustments
I have more questions about valvetrain adjustments.I have a non vtech motor,where is the hole located for the crankshaft?I couldnt find it.Also what are the longtime problems that might arise if I didnt get the valves adjusted within the next few weeks? Would this apply to the non vtec motors....>http://www.bseries.net/html/garage/valveadjust.php
Any help is appreciated.I have a B18A
Yes there is a hole on the left driverside front tirewell.
You should be able to poke a 19mm (I think that's the size) socket with long *** extension through the hole and reach the crank pulley.
You either need to turn your wheel all the way to the side or remove it to access it.
