b16 gurus...where did you wire the 2nd o2 sensor?
as the title says. my b16 swap only came w/ 1 o2 plug. it's getting annoying that i keep getting CEL for the 2nd o2. Do just tap the wire and plug in the 2nd o2 or is there are special place for it?
Jeff-
Jeff-
you wire the 2nd o2 the the appropriate pin out in the ecu.. I am not sure of which pin out.. try hasport.com or elsewhere....
sorry for the vagueness
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
Cyl. 1 & 4 Primary 02 to C16 (white wire)
Cyl. 2 & 3 Secondary 02 to C8 (yellow wire)
