b18b1 at 10psi...can i use 97+ prelude injectors?
i want to up the boost on my jrsc to 10psi instead of 6psi. from my understanding i need to get bigger injectors. so can i use some stock 97+ prelude injectors and
be fine or will i need to get the rc 310cc injectors?
are the injectors on my 98 b18b1 motor saturated?
what size are the prelude injectors? would it be better if i got some rc 310cc injectors to run 10psi on my b18b1 motor?
don't know, that why i'm asking what kind my injectors are. oh yeah, what kind are the prelude injectors too?
i heard that i could run the 97+ prelude injectors and run 10psi on my motor and
i will be fine with those injectors. i just read somewhere that the prelude injectors are 310cc, is that correct? i've also heard that they are 290cc. can somebody verify what size they are?
b18b1 with jrsc
jrsc fmu
walbro 255 hp fuel pump
fpr
aem fuel rail
stock injectors
what will my fuel pressure be if i push 10psi right now on my ls motor with stock injectors?
jrsc fmu
fpr
aem fuel rail
stock injectors
Prelude's are only like 270cc. I guess since your are running an FMU they would be "ok" but I think with running 10psi and stock fuel pressure those are gonna be close to max duty cycle. I would get 310cc personally and tune atleast VAFC hack at a minium. You are just gonna be running richer and richer.
You can use the Lude injectors (the 97+ are saturated), but you will also need a new FMU. The JR FMU is fixed at a 5:1 rise rate. 5:1 is the rise rate for stock injectors.
This type of upgrade is very old skool. With all that is available now, you should really consider doing something that will offer you a little more control and flexibility like the VAFC hack or the SMC+ or better yet, a Hondata if you've got the money.
After you factor in the cost of injectors plus the cost of another FMU, the SMC in particular is an attractive option. It wasn't available when I did my JRSC boost upgrade, so I ended up buying a Cartech FMU. Just say NO to FMU's.
Sonny
so i should get the smc+, 310cc injectors(or keep stock), and ditch the fmu? or what?
can you explain a little more on how the smc+ works?
The 96 and earlier Preludes have peak-and-hold (low impedance) injectors. All 92+ Civics/Integras use saturated injectors. All 97+ Accords/Preludes also use saturated injectors. You can put peak-and-hold injectors in a system designed for saturated injectors by installing the factory resistor box that came in the 91 and earlier Civics/Integras. (see my sig for details)
If you're gonna get larger injectors, get something bigger than 310's. Those aren't really big enough to support a lot of boost and you'll max them out fairly quick.
Here are some of your options for fuel upgrades:
1) RC440cc injectors + SMC (cost = about 350; easiest + good fuel control)
2) DSM450's + my resistor box kit + SMC (cost = about 200; cheapest + good fuel control)
3) RC310 + Cartech FMU (cost = about 425; expensive + lousy fuel control)
4) Hondata + big injectors (cost = 1000ish; very expensive + complete fuel control)
FMU's are old skool and they suck because they offer you no control over your fuel curve and force you to run crazy high fuel pressure. With what we have available to us now, FMU's really don't make sense any more.
The SMC works by manipulating the voltage that the ECU sees from the MAP sensor. The output of the MAP sensor has a direct effect on how long the injectors are held open. By playing with that voltage, you can run big injectors on the stock ECU.
IMO, option #2 is the best and I'm not saying that just because I sell resistor box kits. It is the cheapest and by setting your car up to run peak-and-hold (low impedance) injectors, any future upgrades are a drop-in affair. 440cc is the largest saturated (high impedance) injector that you can get.
I did the FMU upgrade BS back when the SMC/VAFC hack etc were not yet around. I think the SMC and equivalents are nice stepping stone between FMU and standalone.
Sonny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid »</TD></TR><TR><TD CLASS="quote">Sunny you are wrong about the 94-97 Accord uses peak and hold injectors
Just and FYI
Accordhybrid</TD></TR></TABLE>
I never said that they didn't.
I said that 97 and later Accords use saturated.
Sonny
Just and FYI
I said that 97 and later Accords use saturated. Sonny
It can't be the 97 and later injectors are saturated cause that means that the 97 Accord injectors are saturated which is wrong
What you should say is the 98+ Accords are saturated
Accordhybrid
Accordhybrid
Casey
16
Feb 16, 2004 04:44 PM
