FS. SMSP Carsound Cat with jdm donuts and welded ends
FS. NEW SMSP Carsound Cat with jdm donuts and welded ends(i think, I haven't removed it from the box, will do next week though)
I received this as a prize at the ITRexpo with the intention of using it with a header. My plans have changed and I have decided to just sell it.
What do these go for new?
I don't know its worth so PM if interested. Highest offer takes it. Need it gone by mid-May.
Thanks, Scott K.
Thanks, Scott K.
uh not really. you need a donut to fit the cat to the header or else you'll have metal rubbing on metal and an exhaust leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by houston »</TD></TR><TR><TD CLASS="quote">JDM Donuts? are they yummy? get me a measurement on length.. is it 16.5"?
I assume the donut thing was a joke.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2NING »</TD></TR><TR><TD CLASS="quote">does it have an o2 bung and is it 2.25" in diameter??</TD></TR></TABLE>
Bump for a 2003 ITR Expo Participant
It's a 2-1/2" cat to be used with a JDM header and an usdm ITR/LS or 00- GSR cat back. It's OBDII so it has a bung on the outlet. The donut is the JDM spec (65mm or 2-9/16" ID) and has the hardware kit and 3 bolt gasket for the B pipe. Someone should grab it since the current price is $185 for the obdii cat, JDM donut is $18 and 3 bolt gasket is $4.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">
It's a 2-1/2" cat to be used with a JDM header and an usdm ITR/LS or 00- GSR cat back. It's OBDII so it has a bung on the outlet. The donut is the JDM spec (65mm or 2-9/16" ID) and has the hardware kit and 3 bolt gasket for the B pipe. Someone should grab it since the current price is $185 for the obdii cat, JDM donut is $18 and 3 bolt gasket is $4.</TD></TR></TABLE>
Can't get better details then that! Dave, nice *** meow
This is a really old post to reply to....
