best OEM to SIR hood replacement:
Old May 1, 2003 | 04:05 PM
b18crx's Avatar
Default best OEM to SIR hood replacement:
looking for sir hood to clear valve cover. who makes some good ones? cf or fiberglass? VIS? fiber images? seen looks of junk but want quality with small price tag. within reason?
Old May 1, 2003 | 04:44 PM
bryant's Avatar
Default Re: best OEM to SIR hood replacement: (b18crx)
SiR or SiR 'Style'?
Old May 2, 2003 | 01:58 AM
b18crx's Avatar
Default Re: best OEM to SIR hood replacement: (Bryant)
SiR or SiR? is this algebra? 1=1. wanting an SiR to fit over swap. OEM wont close.
Old May 2, 2003 | 04:38 AM
2XS's Avatar
2XS
he is asking if u want an sir hood where u have to do the full sir conversion, or if u want a hood that bumps up like the sir one but still fits usdm lights
Old May 2, 2003 | 07:58 AM
b18crx's Avatar
Default Re: (2XS)
thanks for the clarity. was late when i read the first time. Just an SiR hood for usdm lights. the jdm ones arent as easy to find. later i will go with the on piece front end so to fit a turbo and slicks but for not............should i fab the oem hood to clear, say a hole or dents. dont care for looks as it isnt for show and not a daily.
Old May 2, 2003 | 03:13 PM
bryant's Avatar
Default Re: (b18crx)
The OEM hood clears the valve covers just fine. But first off what motor do you have and what mounts?
Old May 2, 2003 | 03:40 PM
b18crx's Avatar
Default Re: (Bryant)
jdm itr. the motor is in. i put on a black bseries valve cover to take the rub. the hood closes but tight. hard to get open once closed. the oem doesnt fit this swap so either need cf or fiberglass till i change to fiberglass one piece. hasport mounts
i have sort of beat the oem hood up since im using it with tight fit. it did have to compensate for the movement of the engine below. guess ill continue but one side is raised when closed about and inch or two. just looks funny and if i dont go with the one piece, which hood companies (cf or fiber) make good but low cost hoods?
Old May 2, 2003 | 03:51 PM
bryant's Avatar
There are many things you can still do.
-Take out the under lining off the hood. the balck carpet kinda stuff
-If that still doest not help you can get brave and cut your hood, cuttin parts of the skeliton off
-a ZC hood CF/FG or metal will fit.
-a SiR Style hood from FiberImages will work just fine too.
-last but not least, just deal with it 'till you get your FG front end.
Old May 2, 2003 | 03:55 PM
b18crx's Avatar
not only did you read the post, you read my mind. thx.
Old May 2, 2003 | 05:09 PM
evilxkid's Avatar
if you do want a jdm sir hood i have a red one for $75 if you pick it up in reno.
Old May 3, 2003 | 01:53 AM
b18crx's Avatar
Default Re: (evilxkid)
reno,
cant manage that one from atlanta.
Old May 3, 2003 | 02:04 AM
1st-hybrid's Avatar
I'm using an OEM hood with my b18c swap, and it shuts fine with no rubbing. HCP mounts
Old May 3, 2003 | 02:27 AM
evilxkid's Avatar
Default Re: best OEM to SIR hood replacement: (1st-hybrid)
atlanta, thats not to bad. what a 5 day drive.
Old May 3, 2003 | 03:31 AM
EFb18b's Avatar
Default Re: best OEM to SIR hood replacement: (evilxkid)
sounds like a roadtrip who's in?!
Old May 3, 2003 | 06:30 AM
dingusjt's Avatar
Default Re: best OEM to SIR hood replacement: (Redlineracer)
just space out your damn hood latch with some 1/4 inch washers...try that before you start throwing around money unless you really want an SiR style hood...it would look really pretty.
Old May 3, 2003 | 01:01 PM
b18crx's Avatar
Default Re: best OEM to SIR hood replacement: (dingusjt)
you dont say....that works? hmmmm. just might work.
Old May 8, 2003 | 06:23 PM
MisterB's Avatar
Dont mean to rape your post but... sorry
I am looking for a sir hood for a civic with sir front end in good condition, scratches dont matter but i dont want any dents
thanks
Old May 8, 2003 | 09:13 PM
nihkon's Avatar
[QUOTE=dingusjt]just space out your damn hood latch with some 1/4 inch washers...QUOTE]
yeah seriously dude. . I did this too. .it's probably gonna be your cheapest solution. Don't waste money on a cf hood or whatever if it's just a temporary solution. Under a dollar for the washers and you're set. (You might have to trim the insulation a little as well like the other guy mentioned above.)
Old May 9, 2003 | 09:15 AM
Racer613's Avatar
I am gonna have the same problem....I am thinking I need a 1 1/2" to 2" to clear the H22 valve cover. I need an Sir Style Carbo Fiber hood that fits a 91 CRX USDM hoodline...I am thinking Fiber Images, but that pos is 600!
Old May 9, 2003 | 10:19 AM
SEA Hag's Avatar
Default Re: (Racer613)
PasswordJDM.com had the OEM ZC hood for like $115 awhile back.
spinney
47
Nov 10, 2005 03:12 PM
menappi
Aug 13, 2005 06:03 PM
menappi
Feb 16, 2005 12:35 AM
speed_racer012
Mar 10, 2004 04:23 PM
SuperCivic
20
Aug 24, 2002 08:46 PM
