Code 43: fuel supply: Could this be causing my motor to blow white smoke
Old May 1, 2003 | 03:34 PM
mike5809's Avatar
Default Code 43: fuel supply: Could this be causing my motor to blow white smoke
Well when it rains my car sometimes throws a code 43....fuel supply (ive only noticed it in the rain...so i thought that some wires got wet....well it stayed on long enuf for me to check it)
well lately my car blows white smoke sometimes at idle soemtimes at start up....you can read the post here
https://honda-tech.com/zero...&id=6
well someone said it might blow smoke if i have a failing fuel pump. could this be it if my fuel pump was bad ? would it make it blow white smoke
i allways thought the car was running lean since i put the motor in
could i be running extreamly lean that it blows white smoke?
thanks lmk
mike
Old May 1, 2003 | 03:40 PM
dohc-nyne's Avatar
yes indeed ur fuel is running lean....i have a 99 ls and i opened the headers one nite to try and be johnny bad a$$,,but it failed lol...when i opened my headers it threw a couple codes...one fuel system lean...and the other was urs fuel supply lean .... so i closed my headers then cleared my codes and everything was gravy....have ur car checked...i have obd2 by the way...anyone else have input....??
Old May 1, 2003 | 03:42 PM
dohc-nyne's Avatar
u might have a bad o2 conection too...??or missing o2 conections
Old May 1, 2003 | 03:53 PM
bottlefedb18c1's Avatar
Default Re: (dohc-nyne)
if your pump wasnt working you car wouldnt run
Old May 1, 2003 | 04:15 PM
4U2NV's Avatar
Default Re: Code 43: fuel supply: Could this be causing my motor to blow white smoke (mike5809)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote">Well when it rains my car sometimes throws a code 43....fuel supply (ive only noticed it in the rain...so i thought that some wires got wet....well it stayed on long enuf for me to check it)
thanks lmk
mike</TD></TR></TABLE>
I was under the impression that code 43 was an 02 sensor code... I threw this code not too long ago and sure enough when I changed the primary 02 the code went away and everything is fine... Also my a/f gauge quit working when this happened...
Old May 1, 2003 | 05:50 PM
NeoGSR's Avatar
Default Re: Code 43: fuel supply: Could this be causing my motor to blow white smoke (Screech Powers)
white smoke=burning coolant.....sounds like a head gasket to me......
Old May 1, 2003 | 06:36 PM
mike5809's Avatar
Default Re: Code 43: fuel supply: Could this be causing my motor to blow white smoke (NeoGSR)
yeah well see i dont have oil in coolent, or coolent in oil..........and i dont loose any coolent so thats why i didnt think it was headgasket.......and i dont notice a whole lot of performace loss
plus its a new headgasket...maybe i put it in ever so slightly wrong?
oh and code 43 i thought was just fuel system....which is 02 sensor, fpr, etc.....but usually like 95% its just the o2
Old May 1, 2003 | 07:27 PM
P1mpSlap's Avatar
****, just change out the fuel pump. How much is a Walbro now adays? Like 100 bux or something.
Running hella lean = no good
RCautoworks
28
Oct 3, 2011 04:51 PM
Silver89crx
Nov 8, 2007 02:35 PM
SIK IN DA HED
Oct 16, 2003 02:31 PM
Malice
Mar 5, 2002 09:48 PM
B18C-RnVA
Sep 9, 2001 02:34 PM
