HELP! Blowing whiteish blue smoke out the tailpipe!
Old May 1, 2003 | 12:41 PM
3rdGteg's Avatar
Default HELP! Blowing whiteish blue smoke out the tailpipe!
The car is puffing out clouds of white(seems to have a hint of light blue in the color I think) smoke out the tailpipe and the engine hesitates when the puffs come out. It's also trailing a bunch of smoke after the puffs. The fumes don't seem to smell like burning coolant nor oil but some strong burning of something.
What was done before this occured:
1)changed out a coolant line that leads from IACV to T.B.(broke) + bled coolant
2) pulled off valve cover, pulled off far left exhaust cam cap to put hondabond around cam seal(was leaking) + installed cam cap back on & valve cover back on.
The next day, after driving around briefly, the above incident started occurring (smoking).
Any suggestions are appreciated.
Old May 1, 2003 | 01:16 PM
1bad-eg's Avatar
Default Re: HELP! Blowing whiteish blue smoke out the tailpipe! (3rdGteg)
Sounds like your car is backfiring. Did you reuse the old valve cover gasket or did you replace it and the spark plug o-rings. Pull your spark plug wires out and check the spark plug holes. You could have oil in one or a few holes, and that can be causing your back fire.( hesitation)
Old May 1, 2003 | 09:41 PM
3rdGteg's Avatar
Default Re: HELP! Blowing whiteish blue smoke out the tailpipe! (1bad-eg)
new gasket and spark plug boot seals, no oil in spark plug hole. No oil or coolant leak. Oil and coolant level seems to be the same also. Compression in all four checks out good, timing is at 16 degrees, + no overheating.... I'm stumped. Someone please help.
Old May 3, 2003 | 07:01 PM
3rdGteg's Avatar
ttt
Old May 3, 2003 | 07:06 PM
Lord Helmet's Avatar
Have you done a leakdown test yet?
Old May 3, 2003 | 07:16 PM
3rdGteg's Avatar
Default Re: HELP! Blowing whiteish blue smoke out the tailpipe! (sleeperciv)
no, don't have my air compressor here yet (just moved). The smoke just started after doing the above basic maintenanence though.
Old May 4, 2003 | 01:20 PM
3rdGteg's Avatar
come on, where's all the real tech gurus????
Old May 4, 2003 | 01:23 PM
Kamin's Avatar
blue=oil
check all your spark plugs and make sure none of them have oil on it ANYWHERE, you could have disturbed the seal for the spark plug cylinders and where it meets the valve cover
or it could be somthing totally unrelated to what you did, and alot worse.
Old May 4, 2003 | 01:33 PM
3rdGteg's Avatar
Default Re: HELP! Blowing whiteish blue smoke out the tailpipe! (Kamin)
I think I had some oil on the thread of the spark plugs; I replaced the spark plug too btw, I'll check the new one now. I'm gonna try to find a camera & post the old spark plugs, there something weird looking about one of the prongs that I don't know what it could be. I don't think I did anything wrong because it was basic b.s. maintenance; but at the same time, how could it happen right after I did that . Oh yeah, I gapped the new plugs to .044"--is this correct for 93 b18b?
Old May 4, 2003 | 01:39 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">I think I had some oil on the thread of the spark plugs; I replaced the spark plug too btw, I'll check the new one now. I'm gonna try to find a camera & post the old spark plugs, there something weird looking about one of the prongs that I don't know what it could be. I don't think I did anything wrong because it was basic b.s. maintenance; but at the same time, how could it happen right after I did that . Oh yeah, I gapped the new plugs to .044"--is this correct for 93 b18b?</TD></TR></TABLE>
93 b18a....and for LS i normally go .035 i think
Old May 4, 2003 | 01:43 PM
3rdGteg's Avatar
Default Re: HELP! Blowing whiteish blue smoke out the tailpipe! (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
93 b18a....and for LS i normally go .035 i think</TD></TR></TABLE>sorry, my fault let me clarify: 93 JDM = b18b. I'll try gapping it a little tighter also thanks.---&gt; though I don't think that will solve that smoking problem?
Old May 4, 2003 | 02:00 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">sorry, my fault let me clarify: 93 JDM = b18b. I'll try gapping it a little tighter also thanks.---&gt; though I don't think that will solve that smoking problem?</TD></TR></TABLE>
yeah probly wont solve smoke prob, but blue smoke means oil is burning...
Old May 4, 2003 | 09:57 PM
3rdGteg's Avatar
yeah probly wont solve smoke prob, but blue smoke means oil is burning...</TD></TR></TABLE>Yeah I know that....white means coolant and blue means oil, but it was really white, there might've been a hint of blue but mostly white. Though it didn't smell like coolant nor oil burning It's just this bad weird burning smell. Both my coolant and oil level are cool + no mixing of either in the reservoirs.
Old May 5, 2003 | 08:05 AM
88_SC_CRX_Si's Avatar
New User
Running rich will also cause white smoke... If I set my fp a little to high, white smoke will appear... Sooo, you might look in the direction of your fuel system. Also, I have also seen a white cloud of smoke coming from a HF, when something in the dist. was failing...
Old May 5, 2003 | 07:04 PM
3rdGteg's Avatar
Default Re: HELP! Blowing whiteish blue smoke out the tailpipe! (88_SC_CRX_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88_SC_CRX_Si &raquo;</TD></TR><TR><TD CLASS="quote">Running rich will also cause white smoke... If I set my fp a little to high, white smoke will appear... Sooo, you might look in the direction of your fuel system. Also, I have also seen a white cloud of smoke coming from a HF, when something in the dist. was failing...</TD></TR></TABLE>Fuel pressure=stock, dizzy is cool because if something in the dizzy is bad, a c.e.l. would be triggered right?
Old May 6, 2003 | 05:43 AM
New User
That was more for example, about white smoke and fuel on the HF with bad dist..
It "should" throw a code if something was bad in the dist., like you mentioned. However have you checked the ECU itself for any codes, rather then going by the dash light...?
Might take a look at the fuel pressure regulator. It would be next inline for causing to much pressure to build in the system, if it were failing for one reason are another. After that would be the MAP, it has the most control over the injector pulse width.
Old May 7, 2003 | 12:21 AM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88_SC_CRX_Si &raquo;</TD></TR><TR><TD CLASS="quote">That was more for example, about white smoke and fuel on the HF with bad dist..
Might take a look at the fuel pressure regulator. It would be next inline for causing to much pressure to build in the system, if it were failing for one reason are another. After that would be the MAP, it has the most control over the injector pulse width.</TD></TR></TABLE>I checked the codes already, nothing besides the ckf sensor code 54 since i put the motor in (in process of getting obd2 oil pump to fix this) but this has nothing to do with the current problem. So you basicly pointing me towards fuel system problem huh (for the clouds/trailing of white exhaust smoke)? The fuel pressure is cool btw.
Old May 7, 2003 | 05:16 AM
New User
Try and get the ckf code 54 fixed before trying anything else... That could be the main reason why it's running rich, the ECU is in Limp mode.
Old May 19, 2003 | 06:13 PM
3rdGteg's Avatar
*UPDATE* Just for the helluvit, I adjusted the valves and changed the spark plug gap from .043 to the minimum: .039 and the smoke seemed to lessened. Now only sometimes under hard acceleration, there will be hesitation and then a cloud of white smoke puffs out. Still working at it to eliminate the intermittent puffs of smoke.......
Old May 19, 2003 | 06:52 PM
_Endless_'s Avatar
i'm having the same problems too. i got white smoke and from what i know..white smoke=coolant, so i checked my coolant reservoir, radiator, dipstick and oil filler cap for some traces of oil but found nothing.
my SiR is turbocharged using the hack and sometimes when i drive hard in boost white smoke would come out of the tailpipe then it'll subside after idling it. sometimes it doesn't smoke if i drove hard in boost. it's really wierd and driving me crazy.
does your car smoke all the time even when idling? coz my car smokes if i drive it hard in boost but sometimes not and smoke usually subsides after idling but one time it still smoke during idle.
oh btw, i've posted this in the FI section but didn't get any help.
Old May 20, 2003 | 04:08 PM
3rdGteg's Avatar
Default Re: HELP! Blowing whiteish blue smoke out the tailpipe! (_Endless_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Endless_ &raquo;</TD></TR><TR><TD CLASS="quote">does your car smoke all the time even when idling? coz my car smokes if i drive it hard in boost but sometimes not and smoke usually subsides after idling but one time it still smoke during idle.
oh btw, i've posted this in the FI section but didn't get any help.</TD></TR></TABLE>It seems to only "puff" out a cloud of smoke (and trail a little) under hard acceleration and u can feel the hesitation right when it's doing it on the gas pedal. All my fluid checked out okay also.
90hondaccord
May 25, 2014 10:42 PM
Sagara09
Oct 2, 2011 02:11 PM
anjapower
Jun 3, 2009 09:02 PM
Brandyn85
Sep 23, 2007 06:12 PM
Diversion
Aug 12, 2006 11:10 AM
