suspension noise again!! wtf
Old May 1, 2003 | 10:48 AM
justininhifi's Avatar
Default suspension noise again!! wtf
Ok, so i took the rear struts out and put the O-rings between the shock and coilover. Everything is snug and all the bolts are tight. But when i still ride over bumps i hear a little clank sound on both sides. No clue at all what it is. The only thing i can think of is that either the bumpstops are too long, even though i cut them in half, or the peice that is right under where it connects to the top is hitting it, but i dont know why. Or maybe it just does it cause its low. Any help?
Old May 1, 2003 | 11:16 AM
IN VTEC's Avatar
Default Re: suspension noise again!! wtf (justininhifi)
How much is the car lowered?
Old May 1, 2003 | 12:08 PM
no more than 2 inches. its on ground controls but with my finger widths its right between 1.5-2 fingers.
Old May 1, 2003 | 12:12 PM
Aaron M's Avatar
Default Re: (justininhifi)
Goto Autozone, get a can of white lithium grease. Then spray the top 3 coils of your spring with it.
Problem solved.
Old May 1, 2003 | 12:17 PM
i will try that after i get out of my class around 4:00.
Hopefully it will stop or i might go insane. Thanks!
Old May 1, 2003 | 01:16 PM
acatak's Avatar
lets us know if that works
Old May 1, 2003 | 01:25 PM
Aaron M's Avatar
Default Re: (acatak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acatak &raquo;</TD></TR><TR><TD CLASS="quote">lets us know if that works</TD></TR></TABLE>
worked for me
Old May 1, 2003 | 02:27 PM
lshobo's Avatar
Default Re: (SilverB18C1)
try raising the car up a bit and see if the noise goes away. when i was down about 2" my rear passenger side would clunk. i thought it was the exhaust, tried to fix it, but it still clunked. raised it back to a 1" drop and it doesn't clunk anymore. i might try that grease idea...i would like to be lower than 1"
Old May 1, 2003 | 03:25 PM
Aaron M's Avatar
Default Re: (lshobo)
the clunk you here are the coils hitting/rubbing against eachother when they are compressed(or when you hit a bump). spraying grease helps quiet them down.
Old May 1, 2003 | 04:06 PM
grease worked a little. I didnt soak it but i sprayed it on lightly. I might try adding some more. Im gonna raise it about half an inch to see if it stops and if it doesnt ill just live with it. I might tie the spring down to the coil perch to see if that helps any. Thanks for the help guys.
Old May 1, 2003 | 04:18 PM
IN VTEC's Avatar
If that's the case, then maybe you should try some fish tank hose or fuel hose. Cut it to a short length, split it down the middle, and glue it to the upper coils.
Old May 1, 2003 | 05:59 PM
lshobo's Avatar
Default Re: (IN VTEC)
great suggestions, guys. i'll be sure to try them out this weekend. thanks
Old May 1, 2003 | 06:03 PM
Hey, that is a perfect idea. Tomorrow will be suspension day #4. Im trying to get everything ready before i take her to get painted monday.
problematic
Sep 10, 2008 07:19 AM
christiantequila
Aug 22, 2008 09:22 AM
TSAngry
Suspension & Brakes
Nov 7, 2007 09:07 AM
dan's integra
Mar 24, 2007 05:50 PM
narib2001
Dec 30, 2003 09:57 PM
